Block heater fried
Old Jan 23, 2005 | 10:05 PM
Dennist's Avatar
Dennist
1000 watts, equal to 10 100 watt light bulbs staying on all night long.
Old Jan 23, 2005 | 10:18 PM
J.Lauer's Avatar
J.Lauer
Where did you get the 1000 watt info from? Just curious? Holy smokes!
Old Jan 23, 2005 | 10:19 PM
Daryl Hunter's Avatar
Daryl Hunter
Hi Dennist,
Welcome to the 6.0 L forum and to FTE. Please take a moment to review the Welcome sticky post at the top of the forum page. There are links to great threads and other info in there.
Old Jan 23, 2005 | 10:22 PM
Dennist's Avatar
Dennist
Googled it, from The dieselstop.*om
Just type in 6.0L block heater watts in google and shazam, you will find many posts.
D
Old Jan 23, 2005 | 10:24 PM
Dennist's Avatar
Dennist
Hey Daryl,
I will check it out, but am not happy to have to post so many to be able to reply to others......
I sold my 00 powersroke here in 2002 and now they say I'm a new user, go figure.
D
Old Jan 24, 2005 | 06:17 AM
Maxium4x4's Avatar
Maxium4x4
Originally Posted by kb1aah
If I don't plug in my truck below 20 degrees, it will start (with remote) and run rough for about 10 seconds, then continue to run for approx two minutes. Then it will shutdown, wait for 15 seconds and restart. Depending on how cold it is, I have seen it do this routine 5 or 6 times. Is it stalling when the glow plugs shut off? Do glow plugs shutoff after 2 minutes?
Educate me on this subject. Starts and stops, restarts with no input from you? Does it act this way if you normally start the truck with a key?
Old Jan 24, 2005 | 10:25 AM
04 LARIAT STROKER's Avatar
04 LARIAT STROKER
1000 watts!!!!!
good thing i dont pay the electric bill at home!!!
Old Jan 24, 2005 | 11:25 AM
kb1aah's Avatar
kb1aah
Max, I have been meaning to see if it does this when I start it with the key. All that I stated above happens after being remote started. It does restart all by itself after it stalls without any intervention from me.........
Old Jan 24, 2005 | 01:44 PM
dsweger's Avatar
dsweger
1000 Watts....
Same as your average coffee maker!
Old Jan 24, 2005 | 02:52 PM
Daryl Hunter
Or 1.341 Horsepower
Old Jan 24, 2005 | 03:45 PM
Maxium4x4's Avatar
Maxium4x4
Sounds as if the remote start is doing this. The remote I have is programmed for 3 attempts, once started it will not retry if the truck shuts down. An over rev feature will shut the truck down if your system is programmed.
Old Jan 24, 2005 | 05:43 PM
kb1aah's Avatar
kb1aah
If the truck has been plugged in, it doesn't have this trouble. I think the reason it automatically restarts is because the "remote start timeout timer" hasn't expired yet. As far as over rev goes, I have verified that it shuts down if the "engine exceeds twice the normal idle speed."
Does anyone know how long the glow plugs remain on after the engine has started? Could it be proportional to the outside temp? It seems to stall after the same amount of time, each time it stalls.
Restlesswildman
Nov 16, 2014 07:09 PM
MalwareDRay
15
Dec 13, 2013 06:53 PM
batfire2000
Mar 2, 2013 04:38 PM
jtjra
Jan 9, 2012 02:42 AM
PwerStroke99
19
Dec 29, 2008 10:33 PM
