4r55e gear ratios
Old Jan 22, 2005 | 10:17 PM
95Rangerxlt's Avatar
95Rangerxlt
4r55e gear ratios
Hi everybody,this is my first post, I just bought a 97 ranger 2.3 automatic with o/d, my problem is when i am going 60 mph the speedometer says 70mph, it looks like the trans may have been changed at least it has been painted, do transmissions have differant gear ratios, mabee some put the wrong one in it?
any suggestions?
thanks, RICK.
Old Jan 22, 2005 | 11:34 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
I doubt your concern is related to gear ratios, since your truck can only accept the 4R44E and 4R55E tranmissions, both of which have the same ratios:
Ford Automatic Tranny Gear Ratio Info
Maybe the tire size got changed somewhere along the way?
Old Jan 23, 2005 | 12:17 AM
95Rangerxlt
Thanks for the reply, GOOD CALL, I fell stupid, I only checked the tire size on one side, it appears the person I bought the truck from has put a 205x70x14 on on one side and a 215x70x14 one the other side, look like I need to buy another 215x70x14,
I bought the truck 225 miles away from home, I hope I diden't hurt the rear end driving it home,
Thanks again for the help!
Old Jan 23, 2005 | 01:54 PM
95Rangerxlt
well I though that might was the problem, So I put new 215/70/14 tires on the rear but the speedometer is still off about 10 mph, if all 4r55e have the same O/D output ratio someone must have changed the rear end, can this be corrected with a VSS sensor? do they (VSS sensors) differant ratios?
thanks again for your replies.
2gumby2
2015 - 2020 F150
Jul 23, 2016 08:26 AM
huntbywalking
Feb 7, 2013 02:23 PM
RazorbackF150
1997 - 2003 F150
20
Dec 24, 2008 11:34 PM
Clifford II
Apr 18, 2004 11:54 AM
gsx
Apr 7, 2002 11:50 AM
