99 F150 Transmission Problem
Old Jan 22, 2005 | 06:23 PM
ford_blue's Avatar
ford_blue
Just purchased a 1999 F150 4X4 Supercab with 49K with an auto transmission. While driving I noticed a vibration or shudder from the drive line when it changes gears.It more noticable when its under a load or hard accelleration. This truck had an electric brake and must of towed something quite heavy.There is no transmission oil cooler and I'm concerned that the transmission was overheated by the previous owner. The dealer tells me that the vibration is normal and not to worry. Can anyone tell me if this is normal or is the dealer trying to avoid a transmission repair.
Old Jan 23, 2005 | 07:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Hupphauler
Feb 27, 2015 02:03 PM
leatherguy
2004 - 2008 F150
Feb 5, 2015 03:38 PM
GreenRino
Jan 7, 2015 05:42 PM
fishe1
1997 - 2003 F150
Dec 24, 2010 10:03 PM
AngeloP
1997 - 2003 F150
Oct 31, 2006 09:05 AM
