My brand new F250 vibrates between 65 & 70 mph. The dealers (I have gone to two) can't find the problem and they keep telling me it's "normal" with the aggressive tread on my BF Goodrich tires. If that's the case then all F250's should ride the same which they don't. What's the chance that the drive shaft is out of balance? Also the transmission does not engage into drive for at least a 3 count when the truck is cold. According to the dealer that is another "normal" condition. Has anybody else have similar problems and if so what did you find?
And the trans issue is VERY common. Mine was so bad when it was new that the dealer replaced the front pump in mine, said it was losing prime and took a while to draw the fluid back into the pump. Mine would sit for 10-20 seconds in gear before it would suddenly clunk into gear and go.
Thank you for the answers. The truck vibrates in 2 wheel drive and not towing. Makes sense about the front pump losing prime. How did you convince the dealer to open the tranny to correct it?
Thank you for the post but I have been restoring cars a long time and the shift problem is way beyond normal and so is the vibration.
LTNGDRVR, did the transmission show a code for the lost pump prime? The dealer keeps telling me that since there is no code there is no problem. thanks.
Tech drove it and it was obvious, the third time I took it in!
No, there was no code, but there was a TSB when they finally ran the OASIS and looked for it.
As to the vibration, you mention BFG tires, you've changed them out from stock? Stock wheels or aftermarket? Have you had a tire shop check the balance, maybe do a road force balance?
Mine came with BFG`s and his probably did too. Got a new truck once and noticed a vibration like you mentioned. Turned out to be a small dent in the driv e shaft, alum.
Where do you feel this vibration? In the pedals? The seat? The steering wheel? The radio *****? Does the vibration change with truck speed or engine speed? Does it change in pitch or amplitude?
The whole body vibrates and it does not change. It just shows up above 65mph. I did find a Ford technical service bulletin that talks about vibration caused by a lack of lubrication in the drive shaft. I am going to take a look at that Saturday to see if that is the case.
I have a 14 extended cab long box F250, I had a similar issue that's very common with the two piece driveshafts. I had mine in for a shudder when taking off and down-shifting to a stop. The slip joint was apparently not greased very well from the factory. I also had a slight vibration at 42 mph that went away as soon as it was fixed. It probably just needs to be greased.
Just purchased a 2014 F 250 XLT 6.7 DIESEL WITH LONG BED, E3.31 axle ratio. Have driven it 1,000 miles empty, no problems. Had a 5th wheel installed, hooked up my 37' Montana (14,000#, 1,800# tongue weight) and it shudders in 1st gear at 4 mph to just before shift change to 2nd gear. Still get a very little shudder in 2nd and then everything is OK all the way up to 75 mph. No shuddering coasting down or on braking. Dealer says I need to install air lifts to re-establish the pinion angle. Ford specs. for this set up is 23,500# total. I am coming in at 21,500#. I feel like this pinion angle problem should be their responsibility. Have talked to Ford Customer Relationship Center. They are supposed to get with my dealer. There is only 3 5/8" of rear suspension travel from empty to setting on the axle stops. Its a little hard for me to believe the Ford Engineers can't get the pinion angle right to work within the suspension travel.
Just purchased a 2014 F 250 XLT 6.7 DIESEL WITH LONG BED, E3.31 axle ratio. Have driven it 1,000 miles empty, no problems. Had a 5th wheel installed, hooked up my 37' Montana (14,000#, 1,800# tongue weight) and it shudders in 1st gear at 4 mph to just before shift change to 2nd gear. Still get a very little shudder in 2nd and then everything is OK all the way up to 75 mph. No shuddering coasting down or on braking. Dealer says I need to install air lifts to re-establish the pinion angle. Ford specs. for this set up is 23,500# total. I am coming in at 21,500#. I feel like this pinion angle problem should be their responsibility. Have talked to Ford Customer Relationship Center. They are supposed to get with my dealer. There is only 3 5/8" of rear suspension travel from empty to setting on the axle stops. Its a little hard for me to believe the Ford Engineers can get the pinion angle right to work within the suspension travel.
It is because of the weak springs. They made them softer starting in 2008 and it has only gotten worse. They are trying to make it ride like a car.
Getting a set of airbags to restore a level ride is what most do.
I may have to go the airbag route, with the Montana hooked up I still have about 1.5" of suspension left. I thought I was still within spec. without needing the airbags.
