eric jacobo
Old Jan 22, 2005 | 05:13 PM
eric jacobo's Avatar
eric jacobo
Angry eric jacobo
I have a 1972 ford galaxy 500 with a 351 windsor engine, recently I did a top overhaul and is in the process timing and valve adjustments. I have followed the manual to adjust the adjustable rocker arms, and during starts I have back fires through the carburator and very rough running. Any suggestions would be appreciated.
Old Jan 22, 2005 | 07:29 PM
ga302p's Avatar
ga302p
There are several different ways I adjust rockers. The one that always works is with piston TDC, adjust rockers where you can just barely finger spin pushrods. I have never had much luck with the way the service manuals call for.
Old Jan 23, 2005 | 07:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 31, 2005 | 04:28 PM
eric jacobo
I havn't continued with the valve adjustment with this 351 windsor, It seems like the manual does not really work. The last time I adjusted the valve was as follows; # 1 at TDC, tighten the retaining nuts on the intake and exhaust valves until unable to turn push rods by finger, then additional 3/4 of a turn and repeat the process by the firing order. This is by the manual, the end result is allot of back firing through the carburator and diffulty to start. One suggestions was to tighten the retainer nut to a point where you cannot turn the push rods by finger with not an additional 3/4 turn. Would this cause any valve lashing?. Another question, What would be a good preset on the carburator in regards to the fuel air mixture e.g. 3 turns or 4 turns from closed to begin with?, the manual does not give you this settings.
Old Jan 31, 2005 | 05:15 PM
Icicle's Avatar
Icicle
What kind of carb is it? it depends what motor AND what carb, but gut instinct is that 4 turns is WAY too rich, 3 is probably a little too rich, I would start at 2 or 2 1/2
but its really dependent on what carb/motor combo you have
Old Jan 31, 2005 | 07:16 PM
ga302p's Avatar
ga302p
On the valves, I tighten them until you can just barely turn them by hand and stop there. That is with the lifter fully pumped up. If it ticks, tighten the ticking ones up until they stop. On Carbs, I start off at 1 turn on Edelbrock and about 1 1/2 on Holley. I do my best not to use factory carbs, except the Carters on some of the Mopars.
Old Feb 1, 2005 | 10:35 PM
eric jacobo
The carburator is a 2 barrel Motorcraft and 2 turns sounds good. I'll give that a try and see what happens. Thanks a bunch.
Old Feb 2, 2005 | 07:17 AM
71swissaqua's Avatar
71swissaqua
If the engine has stock rocker arms on it then they are non-adjustable postive stop types. Toruqe them down to specifications and you're done.
clint
6t6merc
Jan 30, 2023 01:36 PM
Eric Kropp
Oct 5, 2014 03:27 PM
Draken
Feb 15, 2008 05:01 PM
Draken
Feb 14, 2008 08:25 AM
elsmith
Aug 29, 2001 07:24 AM
