Ho 5.0
Old Feb 1, 2005 | 04:49 PM
scalezy3b811's Avatar
scalezy3b811
Ho 5.0
What is the difference between a regular 5.0 and a HO 5.0?
Old Feb 1, 2005 | 05:35 PM
daerhldgs2's Avatar
daerhldgs2
what year engine?
Old Feb 1, 2005 | 05:37 PM
scalezy3b811
Its in a 1992 Mustang GT
Old Feb 1, 2005 | 09:40 PM
cougar_1987's Avatar
cougar_1987
I know that for 1992 the 5.0 has 225 HP @ 4200 RPM and 300 ft. lbs. @ 3200 RPM. Other than that the HO has a different firing order, heads, cam, pistons. I'm not too sure if the crank and rods are differnt. What non-HO are you comparing it against??? The 5.0's in cars vs. trucks were a little differnt.
Old Feb 2, 2005 | 07:27 AM
desertdave35's Avatar
desertdave35
Here is the main difference between the 2 motors.
<TABLE style="WIDTH: 529px; HEIGHT: 239px" cellSpacing=1 cellPadding=3 width=529 align=center border=0 minmax_bound="true"><TBODY minmax_bound="true"><TR vAlign=top bgColor=#4682b4 minmax_bound="true"><TD width=260 minmax_bound="true">1987-95 HO 5.0</TD><TD minmax_bound="true">Non-HO 5.0
</TD></TR><TR bgColor=#dcdcdc minmax_bound="true"><TD width=260 minmax_bound="true">Higher-flowing E7TE heads</TD><TD minmax_bound="true">Standard "swirl port" heads</TD></TR><TR minmax_bound="true"><TD width=260 minmax_bound="true">Higher-lift HO cam (performance/econony)</TD><TD minmax_bound="true">Lower-lift cam (fuel economy, torque)</TD></TR><TR bgColor=#dcdcdc minmax_bound="true"><TD width=260 minmax_bound="true">TRW forged pistons with reliefs</TD><TD minmax_bound="true">Aluminum flat-top pistons</TD></TR><TR minmax_bound="true"><TD width=260 minmax_bound="true">60mm throttle body stock</TD><TD minmax_bound="true">50mm throttle body stock</TD></TR><TR bgColor=#dcdcdc minmax_bound="true"><TD width=260 minmax_bound="true">19 lb/hr fuel injectors</TD><TD minmax_bound="true">14 lb/hr fuel injectors</TD></TR><TR minmax_bound="true"><TD width=260 minmax_bound="true">Better breathing upper intake</TD><TD minmax_bound="true">Standard flow rate upper intake</TD></TR><TR bgColor=#dcdcdc minmax_bound="true"><TD width=260 minmax_bound="true">Factory unequal-length headers</TD><TD minmax_bound="true">Factory exhaust manifolds</TD></TR><TR minmax_bound="true"><TD width=260 minmax_bound="true">HO/351 W firing order</TD><TD minmax_bound="true">Unique non-HO firing order</TD></TR><TR bgColor=#dcdcdc minmax_bound="true"><TD width=260 minmax_bound="true">225 hp</TD><TD minmax_bound="true">150 hp (155hp in 1988 only, w/dual exhaust)</TD></TR></TBODY></TABLE>
