Flywheel interchangeability
Old Jan 21, 2005 | 08:42 PM
kingcavinee's Avatar
kingcavinee
Are all 302 flywheels the same? I know that the balances are different in some years but i was talking more in dimensions. do the diameters ever change? what about the thickness? The hole reason I was woundering was because I am curently looking for a used flywheel for a 70's 302. I am going to put the 302 in a 1986 F-150. the truck has a 300 in it and i plan to use the same tranny. My major concern is the number of teeth on the 302 flywheel will be different from the number on the 300 flywheel. how can I tell without pulling the 300 out to count them?
Old Jan 21, 2005 | 09:32 PM
Don Senkow's Avatar
Don Senkow
Small block flywheels had either 157 or 162 teeth. The 157 is earlier. The 162 will have a slightly larger diameter to account for the 5 extra teeth. There is two imbalance weights 28 oz. (Early) and 52 oz. I'm not sure what year they changed. You could install the 300 flywheel on the 302, however it will vibrate as the balance will be off.
Old Jan 21, 2005 | 09:40 PM
kingcavinee
so could I just get a different starter to acount for the smaller diameter?
Old Jan 22, 2005 | 05:51 AM
RTM's Avatar
RTM
No, the bell housing locates the starter for the correct flywheel. There is no such thing as a smaller starter or I should say in the terms you're thing. You more than likely have the larger flywheel behind the 300.
Old Jan 22, 2005 | 07:24 AM
Don Senkow's Avatar
Don Senkow
If you had the flexplate that came off the 302 you could have the 300 flywheel rebalanced to match it. However finding a flywheel should not be too hard. I agree the 300 flywheel is 162. The starter is the same, the bell is larger.
Old Jan 22, 2005 | 10:42 AM
kingcavinee
Were could I get my flywheel rebalanced and how much would it cost.
Is there such thing as an 162 tooth 28 oz imbalance flywheel? What year was it made?
Old Jan 22, 2005 | 10:53 AM
RTM's Avatar
RTM
A machine shop can balance it for you and yes there are plenty of the larger fly wheels out there. Most mustangs from around 66 and up got the larger flywheel. Not sure on the year but there out there. Any 351W motor will have this flywheel. One thing to watch out for is the mounting holes for the pressure plate. I am not sure all flywheels have the same patterns for the pressure plate.
Old Mar 30, 2005 | 11:23 AM
Ford Snow Braker's Avatar
Ford Snow Braker
cost to rebalance flywheel
it cost me 80 dollars to get my balanced .
I know that a 1991 300 6 cyl flywheel will fit a 1967 351 w block
Old Mar 30, 2005 | 01:43 PM
RTM's Avatar
RTM
300 6cly are internally balanced and will not work on small block motors. Yes they bolt up but it will shake.
Old Mar 30, 2005 | 10:23 PM
fordxxx's Avatar
fordxxx
If you now have a flywheel with the 70 302 then you need to get an early bellhousing that will match it. Or if you don't have a flywheel now then it would probably be easier to find a late model 351 W flywheel that will have the right 28 oz. balance and should have the same tooth count as 86 6 cylinder. So the 86 bellhousing should work. I got an early 80's I6 flywheel from the local pick-a-part and it has 162 teeth.
Maybe the safest thing is if you find a 351 flywheel then be sure to get the bellhousing too...sort of a matching set.
mh822
102
Dec 5, 2025 03:49 PM
300I6VAN85
May 21, 2024 08:34 AM
kellar
Aug 3, 2007 03:48 PM
oldmansimek
Mar 11, 2007 03:34 AM
sandhillmike
May 29, 2006 04:00 PM
