1978 - 1996 Big Bronco
Anyone using Transgo?
Old Jan 21, 2005 | 11:14 AM
kameronth's Avatar
kameronth
I am getting ready to put in a Transgo reprograming kit in my 88 Bronco with an AOD. Who else has one of these in thiers? How do you like it? Any ups or downs? Thanks!
Old Jan 21, 2005 | 11:51 AM
RJR's Avatar
RJR
I put one in my '73 Bronco, 302 V8/4bbl, 31x1050x15 tires. Would bark the tires when shifting to second when getting on it a little, but I started having trouble with CV joints right after I put it in.
Old Jan 21, 2005 | 05:26 PM
kameronth's Avatar
kameronth
What setting did you use? The higer one or the lower one?
Old Jan 22, 2005 | 11:58 AM
Kemicalburns's Avatar
Kemicalburns
i know someone that installed one in his AOD and it worked for about 6 mnths. now it drives like normal. those shiftkits really arent the best way to improve the performance in your tranny. i know its cheaper but talk to a few tranny shops in your area about beefing yours up properly. it will last alot longer and perform far better. I to was thinking of doing this but after fellow bronco guys came back with similar results its made me wait to build it right the first time ya know.
good luck
Old Jan 22, 2005 | 01:53 PM
kameronth's Avatar
kameronth
Well, I am going to rebuild it also, but I have not even seen any better ones out there yet, I have looked through summit and other places and those tend to be the most expensive.
Old Jan 23, 2005 | 12:00 AM
Kemicalburns
go here www.ckperformance.com/ford_aod_2.html
the one you want is the AOD-HDSR/TPWR one. it comes with the 4r70w gear set that is a lower first and second gear and are also much stronger. this will be the tranny i get when mine finally dies. i know a few other bronco guys running this tranny and they love it.
Old Jan 23, 2005 | 01:48 AM
kameronth's Avatar
kameronth
There is no way I am going to spend that much on a tranny! I could rebuild mine three times for the price of that. Now if I had the money that would be a different story. I am just talking about a good shift kit or something. i maybe go offroading twice a month and very rarley tow, but yet I still want a good firm shift.
Old Jan 23, 2005 | 07:47 AM
stevef100s's Avatar
stevef100s
I've installed several different styles of shift kits. The TransGo is a good one, since you can choose your shift firmness. You eliminate some of the check *****, swap out springs, and drill and pin some of the oil passages. How could it go back to normal shifting after doing all this? lol I think you won't like the firmest setting. The AOD shifts way too hard in this configuration. It will slam shift in 1 thru 3, and the 2 piece input shaft will not take it for long. I would suggest a transmission cooler too, if you don't already have one.
Old Jan 23, 2005 | 12:33 PM
Kemicalburns
it just did go back. strange yes but i rode in it and it felt no different then my stock AOD.
Old Jan 23, 2005 | 02:04 PM
kameronth's Avatar
kameronth
Really? That is strange, I have just heard from so many people that the transgo is the way to go. The tranny that I am going to be putting it in is an 82 and the transgo kit is for 83 and up, so I have to steal a valve body from a newer one and put it in the 82.
Old Jan 23, 2005 | 10:35 PM
Kemicalburns
maybe it was due for a fluid service and filter change. i dont know. it could also be a fluke or por install by these guys to.
Old Jan 24, 2005 | 10:17 AM
RJR's Avatar
RJR
I used the lower setting. The higher one seemed too harsh for everyday driving.
