Questions on V-code spring install
Old Jan 20, 2005 | 10:51 PM
Rcmoneypit's Avatar
Rcmoneypit
I just got my v code springs for my 2001 v10 Limited. I also have the F350 rear blocks. Two Questions. When putting on the v code springs, is there a problem removing the front mounting bolts. One post I found someone had trouble with the lower A/C condenser mount. I have a chasis manual on cd-rom and it says that they just remove and that it shouldn't be an issue, so anyone with experience please help. I'm also going to do new shocks when the springs and blocks go in. Some posts say to use longer or f350 shocks. I plan on either Bilsteins or Rancho 9000's. Anyone with part #'s or first hand experience with this please help. I'm just afraid of putting a f-350 bilstein on the rear since it will be valved for a f-350 spring and it not working correct. With the 9000's I can adjust it. Sorry for the long post. Thanks.
Old Jan 24, 2005 | 12:29 PM
Rcmoneypit's Avatar
Rcmoneypit
Anyone out there put there front springs on by themself. Even if you put a lift kit on with new front springs and did it yourself, do the front bolts on the front springs come out without hitting? Or is it just easier to drop the whole front spring bracket? Any help?
lfthrdr
Feb 6, 2015 04:40 PM
aaedin
Dec 8, 2014 12:12 PM
bigwhitetruck01
May 27, 2012 03:45 PM
SurpriseF350Sport
Dec 30, 2010 01:38 PM
Stewart_H
Aug 17, 2006 11:42 AM
