Sponsored by: Innova
mounting subs in enclosure
Old Jan 20, 2005 | 08:20 PM
KennyG228's Avatar
KennyG228
I am installing two Alpine SWE 1241 subs in a dual enlosure. I need to know what type of sealant do I use to mount the subs in the box?
Old Jan 20, 2005 | 08:34 PM
hondamx320's Avatar
hondamx320
just screw them in the subs sould have come with a thin foam gasket sorta thing run that around the ring of the speaker where the screw go and screw it in
hope this helps any more questions just ask
Old Jan 20, 2005 | 09:26 PM
KennyG228's Avatar
KennyG228
My speakers did not come with a gasket. My enclosure should come next week. Is there anything that I can substitute?
Old Jan 20, 2005 | 11:58 PM
turboguy's Avatar
turboguy
dont just screw em in.. wait and find out what a good glue is... my friend used some sort of glue... I dont remember what... I will ask him tomarrow... but its so air tight! its worth it to wait... I'lll post again tomarrow.
Old Jan 21, 2005 | 09:47 AM
2000silverbullet's Avatar
2000silverbullet
Wouldn't some clear silicone work just as well? I'd rather go with a gasket of some sort if you can, that way if you blow your speakers, you're not dealing with a glue/silicone mess.
Maybe even some thin weather stripping? I don't know, just thinking out loud....
Old Jan 21, 2005 | 11:26 AM
rangerxlt02's Avatar
rangerxlt02
No silicone to seal the subs on the box....avoid that please.
You can go to your local hardware store and get sealant used for plumbing. It's a white pliable material that you would put around the sub edge and then screw down.
Most subs don't even need a sealant if you've carpetted the enclosure.
Old Jan 21, 2005 | 01:20 PM
Schmids4.9l's Avatar
Schmids4.9l
rangerxlt02 is right, you dont need to use sealent if you have a carpeted box. plus when you change subs, your gonna have all the sealent all over.
if your box is just plain wood, put some carpet on it.
Old Jan 21, 2005 | 01:51 PM
KennyG228's Avatar
KennyG228
Thanks for the information.I will proceed when my box gets here!
Old Jan 21, 2005 | 06:51 PM
angus's Avatar
angus
You can get closed-cell-foam weatherstripping in rolls at most hardware stores. It helps to punch holes in the gasket where the mounting bolts go through, otherwise the screws sometimes tear the gasket. If you don't have a set of hole punches, a piece of tubing with the edge sharpened works fine.
Only use silicone or plumbing putty if you NEVER want to remove the driver from the box again.
Old Jan 22, 2005 | 08:31 AM
sk8ingsmurf's Avatar
sk8ingsmurf
I cant say much for weather stripping as Ive only ever used it in a car audio application for building bandpass boxes (and boy does it help to pull your front wall off those boxes). Most subs on the market today do come with those rubber gaskets around them but the alpine ones never have. Carpet will help to seal the box but depending on the kind of weave you get it might not seal it tight. If you want a good seal (albeit kinda messy when you take the sub out), go to a hardware store and buy "non hardening rope caulk", Ive used it before on some H.O. boxes and it seals up wonderfully without bonding the drivers to the box.
Old Jan 22, 2005 | 04:12 PM
Crash687's Avatar
Crash687
Here is a thought, try taking black silicone sealant and putting a thin even layer on the back of the speaker. Let it sit for about an hour, put a very light of white greese/vasoline on the bare wood or even on top of the silicone. Put speakers just barely tighten screws. Let sit overnight then finish tightening. You have custom silicone gasket that is removable.
AndeyHall
May 31, 2011 01:17 PM
dieselkid
Dec 5, 2009 10:35 PM
rat49f6
Jul 30, 2009 11:44 PM
Orlie
Feb 4, 2004 04:45 PM
cozmo
Nov 4, 2002 12:36 PM
