Rear pinion nut size?
Does any one have any clue as to what size socket is needed to remove the pinion nut on a 00 ranger with a 8.8 rear end?
I need to replace my oil seal on the pinion, and I'm trying to round up all my tools before I start.
While I'm at it, I'll be draining my manual tranny and transfer case and refilling it, the ole ranger should be happy!
Thanks for any help!
thanks for the replies, I found out what size it was when I pulled the drive shaft off.
FYI tools needed for pinion oil seal change:
3/8'' drive ratchet
12mm socket
1 1/16 box end wrench or socket (pinion nut)
small hammer
small pry bar
oil pan, and rags
2 or 3 jaw gear puller
possibly a suction gun
If anyone is curious on how to do this, I can explain in detail, but right now I'm a bit short on time.
3/8'' drive ratchet
12mm socket
small hammer
small pry bar
oil pan, and rags
The following users liked this post:
miller_feed
17
11-06-2008 09:13 PM
