Socket size for pinion nut??
Old Nov 5, 2008 | 10:08 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I have the D-80 on my dually and need to know what size socket to use to get the seal out. I hate it when my rear leaks, but I guess it could be worst if my front was leaking.
From what I understand it is I only have to change the seal?
Old Nov 5, 2008 | 02:34 PM
megawatt00's Avatar
megawatt00
IIRC it is a 1 7/8" 6 point. The outside wall may have to be ground down to fit inside though.
Old Nov 5, 2008 | 02:51 PM
miller_feed
Thanks Jim. Man, it's bigger then I thought.
Old Nov 5, 2008 | 03:07 PM
megawatt00's Avatar
megawatt00
Your welcome Rick. It is a good sized one. Do you need the torque specs? I can try and look them up for you.
Old Nov 5, 2008 | 03:11 PM
miller_feed
That would be great Jim. I was told to crank down on it pretty hard to make sure things line up right.
Old Nov 5, 2008 | 03:28 PM
megawatt00's Avatar
megawatt00
Here you go Rick:
Torque Specifications
Description Nm lb-ft
Pinion shaft lock nut 637 470
Driveshaft bolts 136 100
Differential bearing cap bolts 108 80
Ring gear bolts — grade 9 298 220
Oil filler plug — 1/4-inch recess drive 34 25
Differential housing cover bolts (F350) 47 35
Differential housing cover bolts (F450-F550) 61 45
Sensor (ABS) bolt 40 30
Old Nov 6, 2008 | 08:32 AM
mueckster's Avatar
mueckster
When we talked about this a couple of weeks ago, I wasn't sure. I hadn't removed one on a Dana 80. The last ones, I tackled, were the Sterling 10.25 & 10.5 differentials. Jim is definitely right on the size. Snap 0n even sells a special socket for them: http://image.snapon.com/international/pdf/M3586.pdf
You'll need a 'big tool' to get the job done.
Old Nov 6, 2008 | 08:56 AM
miller_feed
Thanks Jim and Roland. That is a big tool, I know my tool is not that big. . Guess I will ask some of the farmers around here to see if they have that size socket I can use. Bet that socket cost major bucks. I know anything with the word SPECIAL with it will cost.
Old Nov 6, 2008 | 09:02 AM
miller_feed
Here you go Rick:
Wow, Jim, 470 ft-lb. Looks like I will have to get my fat neighbor to come and sit on the cheater pipe to get that much on the nut. Maybe I should have said BIG PERSON.
Old Nov 6, 2008 | 09:32 AM
megawatt00's Avatar
megawatt00
I did a little more research on it last night. Some guys buy a crartsman socket and turn the edge down in a lathe.
Old Nov 6, 2008 | 10:27 AM
miller_feed
Darn Jim. I have a grinder, no lathe. Seems like ford would had made it where a regular socket would fit.
Old Nov 6, 2008 | 10:36 AM
megawatt00's Avatar
megawatt00
A manufacturer make it easy?? I guess you'll have to do some precision grinding!
Old Nov 6, 2008 | 01:10 PM
DCSpecial's Avatar
DCSpecial
I'd recommend borrowing a torque wrench to properly torque down the pinion nut vs. just using a cheater pipe or a big impact.
Old Nov 6, 2008 | 04:43 PM
miller_feed
I agree with this. I have customers that own large equip. companys. So I hope I can find something big enough. I try to torque what I can.
Old Nov 6, 2008 | 04:49 PM
rbaker6336's Avatar
rbaker6336
you can also use a torque multiplier,makes life a little easier
