Dashlights Don't Work
Old Jan 20, 2005 | 10:29 PM
skiziks's Avatar
skiziks
First I wanted to apologize for confusing things in this thread.
When I first bought my truck about a year ago the dash lights were out. I suggested that the headlight switch or bulbs needed to be replaced. The previous owner, whom will be referred to as “*** Hat” from this point forward, assured me that it was in the wiring as “everything else checked out okay”. Today I replaced the bulbs (1895) and what do you know, I have lights in the dash.
Jag Red 54 was right too, replacing the dimmer switch fixed the high/low beam problem.
I bought yet another headlight switch after making sure the screw in retainer would screw in properly. This still remains an issue as now the retainer will not screw in far enough to hold the switch on the dash. This will get fixed tomorrow.
Old Jan 21, 2005 | 01:04 PM
Jag Red 54's Avatar
Jag Red 54
Skiziks, I have had the "loose switch" problem too. I had to put a washer in between the switch and the dash. The extra thickness made for enough tension so it would be held securely. John
cwatson1982
Jul 12, 2012 01:31 AM
Rich47
Nov 13, 2011 06:22 PM
Ian 2000
Aug 3, 2011 05:57 PM
ajhawkins
1997 - 2003 F150
Mar 29, 2007 03:36 PM
T2Load
Jan 29, 2005 11:44 AM
