Turn Signal Issues
Old Nov 7, 2009 | 05:49 PM
cwatson1982's Avatar
cwatson1982
Turn Signal Issues
Recently bought a 78 F250 4x4 and am trying to sort out electrical issues. I have one left and it is really stumping me.
My turn signals stop working as soon as I turn my dash-lights on. The headlights themselves don't seem to effect it. With the dash-lights on both turn signal indicators on the dash will come on and stay that way, none of the actual turn signal lights will come on.
Also, using a test light both wires going to the signal flasher become hot when the dash lights are on, otherwise only the blue wire is hot.
anyone have any ideas?
Old Nov 8, 2009 | 01:36 PM
cwatson1982
The lamp sockets were bad/corroded/loose for future reference.
Old Nov 8, 2009 | 09:22 PM
79fordf250pickup's Avatar
79fordf250pickup
my 78 supercab does the same thing only it does it on just the right side. i cant figure it out.when i have no dash lights on my turn signals work great, but as soon as i turn on my lights my right indicator in the dash stays on and my right side signal stops working. please help
Old Nov 8, 2009 | 10:54 PM
cwatson1982
Check the turn signal socket on that side for corrosion and loose wires and check the bulb on that side.
The running light filament in the turn signal comes on when you turn your dash lights on and for some reason leads to that symptom if either the filaments are semi damaged or the ground inside the socket is iffy. (I'm horrible with wiring and just got lucky with a test light so I have no idea what actually causes it!).
You might be able to just turn the bulb a tiny bit to get it to work temporarily (one of mine started working after I played with it a bit)
Old Nov 9, 2009 | 08:51 AM
fmc400's Avatar
fmc400
MSEE
This sounds like a ground issue at the turn signal bulb sockets. I'm assuming you replaced the bulb sockets, correct? Also make sure that the sockets are grounded to clean metal at the body, and make sure you have a healthy ground strap from the frame to the cab, and the engine to the firewall.
Old Nov 9, 2009 | 09:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Also make sure that the sockets are grounded to clean metal at the body.
How can you ground the (replacable) socket since it's made from plastic, and the parking lamp is also plastic?
D1FZ13234A .. Parking Lamp Socket-Plastic / Obsolete
Fits: 1975 F100/350 from serial number C50,001 & 1976/86 F100/350.
Fits: 1975/86 Econoline // 1978/86 Bronco // 1971/73 & 1976 Pinto/Bobcat // 1973 Mustang & Torino.
1973/74 and 1975 F100/350's before serial number C50,001: The metal socket is part of the metal parklamp body, the lens was available separately.
After C50,001, the parklamp body/lens is a one piece plastic assembly, the socket was available by itself.
Old Nov 10, 2009 | 08:39 PM
79fordf250pickup
got it fixed. I replaced the socket with one from a parts truck and it works fine. I was sure it was a ground problem but I guess not.
Old Jul 12, 2012 | 01:31 AM
bluoval21's Avatar
bluoval21
I had the exact same problem on my 78 F100 Lariat with the left turn signal staying on. After reading a couple of these threads, I replaced the bulbs, sanded the ground areas. When none of this worked, I replace both left sockets and everything works perfectly now. Thanks so much for your posts. I would never have fixed it without them.
troverman
Aug 21, 2016 10:32 PM
co997
May 9, 2016 06:35 PM
lanier1974
Mar 29, 2016 09:55 AM
mondo89
Oct 14, 2014 11:14 PM
mondo89
New Member Introductions
Oct 14, 2014 09:16 AM
