Please help
Old Jan 17, 2005 | 02:45 PM
tiljc's Avatar
tiljc
Please help
I have a 1994 F-150 5 spd inline six The fluid in the clutch slave cylinder keeps dropping on me and making it hard to get into gear. Put fluid in and it gets better but I am about to go broke buying Dot 3 brake fluid. Any suggestions on how to identify the leak or why I am losing fluid. Thanks for your time.
Old Jan 17, 2005 | 04:16 PM
buzzbait65's Avatar
buzzbait65
I have never seen a 94, but on other trucks, there is a master cylinder, the line going to the slave cylinder and then the slave cylinder....you fill the "master cylinder", the slave is down at the tranny, if there is a leak it is in one of those three items, if you cant find the leak, check behind the firewall where the master cylinder is mounted and see if it is leaking into the cab out the back seal......
02GrayPowerStroke
Sep 16, 2018 02:30 PM
turbill
Dec 18, 2010 04:31 PM
ntstock93
1997 - 2003 F150
18
Mar 27, 2010 11:31 AM
redfire42
18
Jun 30, 2008 12:38 PM
1975Ford
Oil & Lubrication
13
Jan 4, 2007 11:31 AM
