long time no see, fellers!
I am now putting a '99 5.0P in a 66 bronc!
I was wondering if anybody knows of a crank pulley that would work on the 4-bolt 50 oz dampener that would also co-exist with the current v-belt settup that is on the 289. I am using a '69 timing cover and water pump.
Any thoughts?
I know you can buy a dampener for this swap, but i would much rather just get a pulley.
ok i have found the cure!!!!!!!!!!!!
Profesional Products (they're main products are intake manifolds)
They make a balancer that has both bolt paterns and the counter weights are removeable, so with one balancer, you can have zero, 28oz, or 50 oz.
and it sits back far like the pre '78 and you can but spacers to move it out from there.
So in conclusion: One dampener that will replace any other dampener on any ford small block!
I bought pn 80007
i will not need a spacer, and this model comes with the 50 oz weight.
And last but not least....... $69.00
