1978 - 1996 Big Bronco
4x4 doesn't work after trailer tow
Old Jan 16, 2005 | 04:10 PM
rpxr400's Avatar
rpxr400
Question 4x4 doesn't work after trailer tow
I have a '93 Bronco. I rented a U-Haul trailer which blew out my brake lights and turn signals, and I'm assuming that it also blew something in my electrical system related tot he 4x4.
I replaced the fuse for the turn signals, etc, and still no 4x4. I pulled and checked every single fuse under the dash, as well as the distribution box under the hood - nothing else blown. The 4x4 was working fine before this.
The 4x4 light no longer comes on. I can hear a faint click, but the transfer case does nothing.
Are there any other relays, breakers, etc that could have blown, or that I should check?
The Chilton manual is no help at all. Other than this and the brakes/turn signals, everything else was ok.
Thanks,
Rick
Old Jan 16, 2005 | 04:18 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 17, 2005 | 03:50 PM
bgblktruk's Avatar
bgblktruk
Whoa sounds like a bummer. Do you have shift on the fly four wheel drive? Push button t case or manual? Other ways of asking that question is do you have automatic hubs or manual, do you have a gear shifter for four wheel drive in your truck.
I think we can help
Mike
Old Jan 18, 2005 | 09:21 AM
rpxr400's Avatar
rpxr400
Mike,
It's electronic all the way. Shift on the fly 4wd, including the auto-locking hubs and transfer case.
I realized after my initial post that I probably should have mentioned that. I didn't realize some Broncos came with manual.
I may "upgrade" to manual hubs after reading several posts here, but I'd like to fix this issue first.
Thanks,
Rick
Old Jan 18, 2005 | 01:47 PM
DcSkater602's Avatar
DcSkater602
it may be the little motor that puts the 4wd in. It has a reset button so dont let a mech. bs you into a $400 one
Old Jan 18, 2005 | 02:46 PM
bgblktruk's Avatar
bgblktruk
I am sorry but I don't know much about those systems. I will look into it a little and see what I can find out. I would start by checking that motor and make sure its getting power and sending it. It sounds to me like either it was shorted or a fuse\circuit breaker\etc blew either protecting the circuit or because it was overwhelmed by the short.
Good luck and let us know what you find.
Mike
Old Jan 18, 2005 | 03:27 PM
aurgathor's Avatar
aurgathor
I'd think you either blow a fuse or a fusible link somewhere (most likely) or the T-case motor had died on you. Check if the motor gets power when you engage 4x4 -- if not you probably got a blown fuse, if it gets power you probably need a new motor.
Old Jan 19, 2005 | 08:32 AM
rpxr400's Avatar
rpxr400
skater...where is the reset button? That may be what I need.
aurgathor - are there any fusible links in the system outside the fuse box and distribution box under the hood ?
Really stupid question - how do I check if the motor gets power when I press the button? I imagine I need to get somebody to press the button, and there is probably a push-on connector at the t-case that I'll check for power with a meter when pressed?
Thanks for all the suggestions.
Rick
Old Jan 19, 2005 | 12:28 PM
93bronc84's Avatar
93bronc84
I also have a push button automatic 4x4 and was wondering the same, as well as where any other breakers are ie: under the hood?
Also not sure if it needs a new threaad but I was wondering if I could switch autolocking to manual lock system?
Old Jan 19, 2005 | 01:21 PM
aurgathor's Avatar
aurgathor
There should be some wire(s) going to the motor; either tap onto while still connected, or just lift the connector and see if there's power there.
Old Jan 20, 2005 | 05:51 PM
RRobben's Avatar
RRobben
Hey 93...
swapping the auto locking hubs to manual hubs is probably the first and most popular modification I've seen discussed on this forum. It's painless, and fairly cheap even if you take your rig to a shop and have them do it. Warn Premium hubs seem to the be the hub of choice here. That's what I'm running and I like them a lot.
Old Jan 20, 2005 | 07:13 PM
DcSkater602
ill ask a buddy of mine where it was...he took it to one mechanic and he told him he needed a new motor...took it to another and he hit the reset and it was fine...this was on a 90 ranger..but hey
CA-Cowboy50
May 13, 2015 09:59 PM
351Cleveland C4
Jan 20, 2014 07:49 PM
John Puig
Dec 7, 2010 05:20 PM
Glockem45
All Things Towing
41
Nov 12, 2010 05:56 PM
southbound35west
Nov 30, 2009 08:36 PM
