7.3 Oil Cooler Question
Old Jan 15, 2005 | 11:29 PM
oskiford's Avatar
oskiford
I just finished reassembling my 7.3 after having some work done to correct a little hole in my block. One question I had was whether I should have disassembled and cleaned the oil cooler. It's not too late ... but I wouldn't mind blowing it off if it won't make much difference.
Old Jan 16, 2005 | 01:00 AM
sealguy's Avatar
sealguy
What caused the hole in the block? If the cause left metal shavings or chunks in the oiling system, I think a cleaning would be in order.
Old Jan 16, 2005 | 10:51 AM
oskiford's Avatar
oskiford
My machine shop found a void/crack in the back left cylinder. He bored it out and put a sleeve in. In the process of cleaning up I have found very no evidence of metal shavings. I guess I was wondering if the contaminated oil (from antifreeze) would mess up the cooler ... or would it eventually flush itself out?
Old Jan 16, 2005 | 11:40 AM
sealguy's Avatar
sealguy
I don't think the antifreeze would mess up the cooler, but I would do an oil change to get rid of the antifreeze. Antifreeze does'nt evaporate like water.
Old Jan 16, 2005 | 11:58 AM
Spectramac's Avatar
Spectramac
If you've got milkshaked oil in the cooler it will need to be flushed out (if you can). Oil coolers are very hard to clean out, impossible if they have any metal shavings in them. Anti-freeze is pretty hard on bearings.
1984F2506.9
Jun 15, 2014 03:16 PM
tomthelegend
Feb 1, 2014 11:33 PM
83f2506.9L
Nov 27, 2012 08:21 AM
Allegheny
19
Nov 30, 2011 11:52 PM
soobad
Jun 4, 2006 06:58 PM
