rollerizing a C6 ?
Old Jan 13, 2005 | 11:57 PM
jav409's Avatar
jav409
rollerizing a C6 ?
Someone in another tread mentioned somthing called "rollerizing" a C6 to get less HP drain on the enging, Does anyone have any info on this or a site to go to get info ? Also can a taller 1st gear be installed like a 3.05 insted of the stock one ?
thanks
Old Jan 14, 2005 | 11:14 AM
beeboy's Avatar
beeboy
you can get a lower 1st and 2nd gear. Ford sells a set, more common is to drop in the e4od planetaries.
Old Jan 14, 2005 | 11:52 AM
84-250's Avatar
84-250
tci sells a low drag kit:"This low drag set for the C6 replaces the troublesome stock thrust washers with needle bearings that reduce friction and extend transmission life. Set includes forward planetary assembly, forward clutch hub, reverse planetary assembly, reverse ring gear, rear sprag inner race and roller bearing rear park gear. All thrust washers are replaced by a needle bearing." $261.39 from summit
tci low gears with low drag bearing installed:$615.69 from summit
Old Jan 14, 2005 | 08:37 PM
Don Senkow's Avatar
Don Senkow
I have bought a TCI roller kit. Some of the parts in it had Ford packaging. It comes from the E4OD trans and is good stuff. You can also get the same parts from Ford Racing (Ford Motorsport)...Don
Old Jan 14, 2005 | 08:45 PM
monsterbaby's Avatar
monsterbaby
Actually Ford no longer sells the wide ratio gearsets as of about 5 yrs ago, but there are several other places to get them or as you mentioned use e4od, or 4L100 gearsets. and the origanal poster was asking for 3.05 actually these drop first to 2.71, and second to 1.56.
Old Jan 15, 2005 | 12:59 AM
beeboy's Avatar
beeboy
I guess I should pay better attention!
Actually ford is selling the lower ratio kits.
http://www.fordracingparts.com/parts...tKeyField=3707
Old Jan 15, 2005 | 08:18 AM
monsterbaby
[QUOTE=beeboy]I guess I should pay better attention!
QUOTE]
Guess it's my turn to start paying attention, if you notice they mentioned discontinuing the M7398-c kit which is the old one and only used a 4 pinion planetary but thats cool that they brought it back as the 6 pinion using hte 4L100 parts like I was talking about I didn't know they had done that.
Thanks for that info.
Old Jan 20, 2005 | 10:42 PM
bpatton74's Avatar
bpatton74
This is what I found while looking for a lower transmission ratio
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=7939570161&ca tegory=33727
I don't know if it is the same as the Ford kit though. It is alot cheaper (quality???), I don't know he seems repitable.
Old Jan 20, 2005 | 11:07 PM
beeboy's Avatar
beeboy
I've bought from them with no problems. Call them if you have any questions about it.
6978sghfbjklgdfsjhkl
15
Jan 25, 2014 06:58 PM
Killgore
Jun 19, 2013 02:41 PM
C-Leigh Racing
28
Jan 10, 2009 10:07 AM
travlnman
3.8 & 4.2L V6
Nov 30, 2004 05:37 PM
jruppert00
Jan 3, 2004 01:50 PM
