Drilling into headliner
Old Jan 13, 2005 | 06:18 PM
Country4.2's Avatar
Country4.2
I want to put a cb radio in my 04 f150 Heritage. I would like to mount it on the ceiling of the cab in the middle above the rear view mirror. I was wondering if anyone has any experience with screwing/drilling into their headliner. I know the headliner itself will not hold the cb but I was wondering if there was enough metal behind the headliner to drill/screw into without drilling through the roof. Thanks for any info you guys can provide.
Old Jan 13, 2005 | 06:20 PM
true4.2's Avatar
true4.2
Ooo, that's a new one on me...if only Jimmy Dean were to see this post. I'll bet he'd know.
Old Jan 13, 2005 | 11:15 PM
rmanTX's Avatar
rmanTX
how heavy is the unit?
Old Jan 14, 2005 | 09:01 AM
Country4.2's Avatar
Country4.2
It is probably around 2 pounds, I am at school right now but when I get home I will get an accurate weight and get back with you. But by guessing I would say about 2 pounds.
Old Jan 14, 2005 | 09:55 PM
rmanTX's Avatar
rmanTX
if it's just 2 pounds, i would mount the screws facing down, heads up. The headliner is actually pretty stiff, i've removed it before. But I would definitely either make a large flat piece of fiberglass to mount to, or something considerable. Possibly a piece of sheet metal, like 3'x3'.
With sheet metal, you can curve it to the contour of the roof. Just remove the rubber door seal, the rear quarter plastic pieces, the front a-pillars (handles first), and then the headliner. Slap the sheet metal in there, pre-drilled with the correct holes, and take some measurements of fitment/placement. Then drill it through the headliner. Run all your wires down the A-pillar and reassemble.
Hope this helps. At one time, I wanted to make a fiberglass headliner to mount amps, and give me more room for subs behind the seat of my RCAB. So i've put a lot of thought into roof mounting....things.....
rman
Old Jan 16, 2005 | 09:31 AM
true4.2's Avatar
true4.2
That actually sounds like a good system to go by, too bad I would never have thought of it.
Old Jan 16, 2005 | 10:09 AM
Country4.2's Avatar
Country4.2
I didnt realize the headliner was that strong, (never had it out before), thanks for the idea.
Old Jan 16, 2005 | 03:48 PM
rmanTX's Avatar
rmanTX
if you use a support, like sheet metal, remember that generally the larger it is, the more stable it will be under the headliner.
Old Jan 17, 2005 | 06:31 PM
Country4.2's Avatar
Country4.2
Is there any metal supports behind the headliner? Any brackets of any kind? Or can you not see them because of some kind of insulation? I am planning on installing my cb soon, but right now in Ohio the temp isnt going above 20 degrees and thats too cold for me to work on my truck.
davewave649
18
Apr 8, 2021 11:33 PM
Rusty_S
May 7, 2014 08:13 PM
juang316
Sep 2, 2013 08:35 PM
mpc07005
Dec 26, 2011 01:31 PM
Gage2502
Aug 2, 2011 03:38 PM
