CB Mounting/Headliner
Old Dec 25, 2011 | 11:35 AM
mpc07005's Avatar
mpc07005
So I got a CB for Christmas, and now I need to figure out how to mount it. I was thinking up on the headliner between the visors, but I don't know whats up there. Anyone have any pics of the cab roof without the liner, or know if this is feasible? Otherwise I'll just pop it in the dash somewhere. Antenna's going on the drivers side cab corner.
Old Dec 25, 2011 | 11:56 AM
Edgethis's Avatar
Edgethis
LMC Truck Parts - Page 104
You could look into this headliner.
Old Dec 25, 2011 | 11:58 AM
DBGrif91's Avatar
DBGrif91
Do you already have an overhead console of some kind? If not, there shouldn't be anything to worry about ruining. There's a couple of inches between the inner and outer cab shell, so it's not like mounting screws will end up through the roof.
I can't remember who it was but somebody here cut a hole in his headliner and then ran the wiring between the headliner and cab, so it looks like a factory mount.
Old Dec 25, 2011 | 07:26 PM
ManicMike's Avatar
ManicMike
I can see the idea you have. Though I wouldn't stick it up there.
That's where I mounted mine. You also have to remember you still need a 12v source and ground. Plus a place to run the antenna wire. I simply got my test light out and found a key on power source then found a ground. For the antenna wire I poked a small hole though the transfer case boot then ran the wire down the frame and up the back of the cab to where I mounted the antenna on the bed rail.
Old Dec 25, 2011 | 08:00 PM
mpc07005's Avatar
mpc07005
Perfect! I was hoping for a space, or at least some reinforcing rails. Antenna wire will be above the liner and I have a bus bar in the cab already for power. I would have put it under or in the dash, but the shift lever (manual) takes out a lot of space and it's a Galaxy DX939, so it's 10x8x2.5 (LWH), little on the large size. This setup is the farthest away the antenna and wires, including power (after the bus), they can be from noise sources, except the rear drivers side speaker, and that's getting some extra shielding. Probably strip the liner on Wednesday and have it buttoned up on Thursday.
Old Dec 26, 2011 | 12:33 AM
mgroshong's Avatar
mgroshong
I know this doesn't answer your questions but here is my cb on the roof, same spot your putting it.
Old Dec 26, 2011 | 03:51 AM
TexasGuy001's Avatar
TexasGuy001
I'd mount it under the dash. There is no way I'd modify the headliner or dash for a CB.
Old Dec 26, 2011 | 04:28 AM
Skip1970's Avatar
Skip1970
u could mount it under the drivers seat.
Old Dec 26, 2011 | 01:20 PM
Phy's Avatar
Phy
Here's a pic of one without the headliner:
It had a radio there at one time. There's at least 1.5" of clearance for the screws. I'll be putting in a CB there soon. The antenna will go in the middle of the roof, & the power and PA wiring will go under the windshield trim & down the A-pillar trim to get under the dash...
Old Dec 26, 2011 | 01:24 PM
jk89cat's Avatar
jk89cat
i have mine on one of those shelf its. i can give you guys pictures but it will be the weekend. (the truck is not by my house)
Old Dec 26, 2011 | 01:31 PM
White 97 xlt's Avatar
White 97 xlt
Thanks for the picture.. I've always wondered what was there, 3 reasons I didn't know: I've just been too lazy / afraid I might mess up the headliner / didn't have a need.
To be honest I think lazy is the biggest reason!!!!
littleapple
Sep 1, 2024 03:27 PM
Fert
Jun 26, 2018 03:28 AM
Richard Aarts
Jan 22, 2018 07:27 PM
Ranger4x4
1983 - 2012 Ranger & B-Series
Mar 11, 2007 11:46 AM
K-9111
2004 - 2008 F150
Aug 8, 2004 11:30 AM
