has any one got a diagrame showing dimensions of 57/60 f100 frames or know of where i could get a set?, in one of the replies to a question about 56's a link was included showing all cab and chassis measurements with a diagram, is this available for the next series?
cya...gary
I made a drawing of my 1960 F-100 panel truck frame on AutoCad 2002. This drawing has all locations for suspension, body, gas tank, etc., dimensionally located. The problem is that you would have to have AutoCad to open up the drawing. If you have the AutoCad 2002 program, I can Email you the files.
Sounds like those autocad drawings might be the way to go. I checked my '58 shop manual, there are frame dimensions listed in Chapter 6, page 22 but not the depth you're looking for. You might possibly find an assembly manual or some collision repair info from that era that has better information.
hey guys, i was offered a cad program last week, but it had no imfo with it, a freind had updated his plasma bed and no longer uses it, i'll find out what it is and if any good i'll take u up on your offer.
cya...gary
Hey fellas, I checked my body builders layout book, apparently I had that and the book I actually have confused. The only demensions I have are the same ones that kenny just posted in the "The Brazilian F100 again..." post 2nd page.-4speed
The dimensions given in the post Mr4Speed mentioned are:
F-100, F-250, P-350
Width at front..........................34"
Width at rear...........................34"
Front End Dip............................1-3/4"
C to C Front spring hangers........44-5/32"
C to C Rear Spring Hangers.........51-21/32"
Rear Axle Kick-Up......................2"
Also, I have my 59 short wheel base frame available and can take whatever additional measurments you think might help.
I intend to take some pictures and add some dimensions before I mount the cab.
If the frame rails are 34" wide at the rear (just like the 48-52 and 53-56) then I assume the width between the inner edges of the rear rails is around 29 to 29.5 ?
