I wouldn't think there would be much difference in the width but the length might be different because of wheel base and mounting points would likely be different also. I don't think the frame got wider until the late 70's
Why? You'd be defeating the purpose of all the innovations w/ the later model frame.
And the last I looked, '55 frame is narrower than the '57-'60 frame & wouldn't fit.
Hello Walston, how much wider is the 60 frame compared to the 55. Col Flashman states that the later frame is wider not that I'm doubting him, I thought it was in the late 70's when the frames got wider
I can go out and measure the 60, but I don't have the 55.
Reason is I have built a 55 with TCI mustang II ft end and a TCI 4 link rear with 4 wheel disk breaks and am having a hard time finding a cab in good shape. I have seen several local 57 - 60s and thought that may be a way to go.
My Cab is in good shape with the exception of the floors, but I don't think I am up to changing it.
I just gotta ask....What great inovations did these frames achieve anytime from 1953 thru 1964????????
