bonehead things done by previous owner, post up
Old May 5, 2012 | 12:14 AM
  #121
kedwinh's Avatar
kedwinh
Originally Posted by ghanson
PO on my old truck repainted it but decided not to remove anything and crappily taped off badges. So parts of my mirrors were white, all the tailgate hardware, including the cables and rubber bumpers were white.
That sounds like one of the old Earl Scheid paint job. Had a friend get one of those back in the 70's. That's exactly what they did, masking tape everything. Great looking 50-75ft paint job.
Old May 5, 2012 | 07:10 AM
  #122
ghanson's Avatar
ghanson
Veteran: Marine Corps
Hahaha, he get all the paint runs too? Granted, paint jobs aren't too critical on an old pickup.
Old May 5, 2012 | 07:18 AM
  #123
fellro86's Avatar
fellro86
That sounds like one of the old Earl Scheib paint job. Had a friend get one of those back in the 70's. That's exactly what they did, masking tape everything. Great looking 50-75ft paint job.
Taping was a premium. most times they just greased what you didn't want the paint to stick to...
Old May 5, 2012 | 05:09 PM
  #124
Leaf's Avatar
Leaf
That's a great idea! I'm gonna do that when I get around to painting mine...
Old May 5, 2012 | 05:26 PM
  #125
fellro86's Avatar
fellro86
They were sloppy with it, and it is generally petroleum jelly for the grease.
Old May 6, 2012 | 03:08 AM
  #126
kedwinh's Avatar
kedwinh
Hadn't even thought about that but it does make sense. Just took it for granted they used masking tape, it was obvious they did remove anything.
Old May 6, 2012 | 10:43 AM
  #127
bremen242's Avatar
bremen242
The best thing that I've found on my new-to-me f250 is the lack of maintenance. 170K on the original plugs. Well, 5 of the original platinum plugs. Three plugs were changed. One of them was so rusted, I actually broke the metal part of the plug off trying to remove it. I have to use wax and an ez-out to remove the rest.
The steering box has about 50 degrees of play in it.
Good thing I only paid $350 dollars over scrap price..
Old May 7, 2012 | 03:58 PM
  #128
Citizenrain's Avatar
Citizenrain
found a few items on mine, more tales of hacked wiring mostly..
Bought my 84 from the original owner and he made it clear that while he took care of it, he was not mechanically inclined. He was a high-powered radio aficionado and had 2 radios installed in the cab (one radio receiver still lives in there) and a mount for a whip antenna stuck on the front bumper (also still there). Additionally, he had some aftermarket lights in the grille.
Everything was placed on the horn circuit and wired in using small home appliance UL wire.
The other thing that gets me is the maintenance. It's got a fresh 351w in there now, but the original engine was in appalling shape when we got it apart. Only 100k miles but it looked like it hadn't received more than a couple oil changes in it's life.
Old May 8, 2012 | 02:52 PM
  #129
Bertzilla's Avatar
Bertzilla
Previous owner was an idiot.
Front tank pump quit so rewired to pull only from rear tank.
Bypassed tank selector switch altogether.
Installed regular fuel filter inline before the high pressure pump.
Spliced broken fuel line with what looked to be part of an ink pen.
Apparently removed fuel line connectors with a hammer and screwdriver.
Bypassed tank selector valve in a manner that can only be described as "astounding."
Basically did close to 2k worth of damage to avoid buying a $100 fuel pump.
Idiot.
Luckily I don't pay full price.
Old May 8, 2012 | 03:03 PM
  #130
86ford185's Avatar
86ford185
Mine had the fenders cut in the front to fit bigger tires. But at least they put some nice fender flares on it so its unoticable until you open the hood, bc they cut some of the Inner fender too.
Old May 8, 2012 | 03:20 PM
  #131
82f100460's Avatar
82f100460
today, I stayed home from work and I spent most of the day laying around with a headache and trying to help out a few fella's on here.
I did look at my truck sitting in the driveway...as was pretty happy there is no longer a puddle of tranny fluid forming under it
I did purchase 2 more Ford manuals today and my Holley tuning book came in the mail...Library is getting bigger
Old May 8, 2012 | 04:59 PM
  #132
b27925's Avatar
b27925
bought 86 stepside
the wood in the bed replaced with plywood and no braces
smog, egr, and knock senser gone
removed sway bar on rear for some traction bars that were not the right lenght
aftermarket cruse control half hooked up
4.56 gears with welded carrier
more oil leaks than there are gaskets i thinkl
Old May 8, 2012 | 10:38 PM
  #133
Fordzilla80's Avatar
Fordzilla80
The tailgate handle rods were held to the handle with thin gauge non-insulated wire. Instead of buying cheap guides for less than $1, he used wire that eventually stretched out and made the rods come loose.
Old May 19, 2012 | 01:40 AM
  #134
00Boss's Avatar
00Boss
^^ HAHA thats actually what I did lol. I used aircraft safety wire instead of electrical wire though. If that stuff stretches under the use of my tailgate then the army has far worse issues to fix then loose handles.
Benztechnc
79
Jul 23, 2019 07:33 AM
cntryby
May 30, 2017 09:31 PM
caly350
May 22, 2017 01:24 PM
flynbya2
39
Jun 18, 2016 07:33 PM
The Grinch
Jun 26, 2011 10:04 AM
