gvwr
Old Oct 21, 2002 | 11:38 PM
82F100PU's Avatar
82F100PU
gvwr
i need a little help please!
will upgrading the tires, springs, overload springs, shocks safely increase the gvwr on my little f100?
thanx for any responses.
Old Oct 22, 2002 | 09:00 AM
Whitey078's Avatar
Whitey078
gvwr
perhaps a bit, but you also need to replace your axel. though after getting stiffer rear spings (mine were shot so why not) i did carry 4000 pound pallet of cement int eh back of my f-150. though it was a short distance and i don't suggest it as the axel may be damaged by this amount of weight. perhaps you can find a f-250 thats been smacked up in front and take the rear suspension/axel?
Old Oct 22, 2002 | 09:16 AM
Franklin2's Avatar
Franklin2
gvwr
Officially you can never go over the GVWR of the door sticker of the truck. Stiffer springs and better tires will make it handle better with a load, but there are other things to consider like the brakes and the frame. Can you overload your truck and get away with it? Sure. Can you use your truck like an F250 all the time? No.
Old Oct 22, 2002 | 10:55 AM
Kenworth's Avatar
Kenworth
gvwr
Its a F-100 is the lightest fullsized P/U Ford built so don't expect to carry much these trucks were mainly designed for daily driving and packing light loads. Beefing up your springs isn't going to give you extra load carrying capacity your axles and frame isn't going to take the extra strain. If you want to haul heavier loads with your truck get a larger truck even a F-250 is too light nowwadays to carry some of the new campers.
Old Oct 22, 2002 | 07:37 PM
brown 4x4's Avatar
brown 4x4
gvwr
Old Oct 22, 2002 | 07:39 PM
82F100PU's Avatar
82F100PU
gvwr
Thanks for the suggestions.......that could be worth a try!
tsipi
Apr 17, 2023 03:54 PM
Nathan Plemons
20
Mar 13, 2017 09:51 AM
MTMike
Oct 26, 2013 10:09 PM
Jrhere2003
Jun 10, 2010 02:54 PM
bucci
May 3, 2010 01:33 PM
