Increasing GVWR/GCWR
Old Oct 26, 2013 | 05:02 PM
MTMike's Avatar
MTMike
What does it take to increase the GVWR and GCWR of a 2000 F350 PSD SC LB SRW? I need to get it from 20k up to about 23k and able to handle a pin weight of a 5th wheel trailer at about 3200 lbs.
Do I need to change things like SRW to DRW, change drive ratio from 3.73 to 4.10 and maybe add beefed up springs? How about the 4R100 tranny - would it handle it?
Anyone BTDTand have a cost estimate?
--mike
Old Oct 26, 2013 | 05:43 PM
RV_Tech's Avatar
RV_Tech
Legally the rating is what it comes with from the factory. Mods do not change that.
Steve
Old Oct 26, 2013 | 06:01 PM
t.scottNDU's Avatar
t.scottNDU
As far as the tranny goes, I would definitely add a 6.0 cooler and an external filter. As well as keeping clean ATF in there every 25-40k.
As far as suspension goes, no where near my area of expertise. At those weights, frame strength could come into question, don't know.
Old Oct 26, 2013 | 06:04 PM
BWST's Avatar
BWST
Got Data?
Some good threads over at rv.net on this. I decided to stay under the 20K GCWR due to the brakes, but I did some upgrades to the rear suspension to handle a heavy camper and tow a boat, so I exceeded the GAWR for the rear axle and the GWVR of the truck itself.
The F350 has some good upper and lower overload springs that you can engage early with a product like Torklift's stableloads to gain a lot of capacity. Airbags can add even more. The rear axle itself is capable of 9750lbs based on my research, but limited by the stock tires. I upgraded the tires/wheels to 19.5" commercial (Toyo M143) to get up to 9610lbs on the rear. I go over that slightly with the Host camper and the boat in tow. Good shocks round out the package.
Old Oct 26, 2013 | 06:06 PM
BWST's Avatar
BWST
Got Data?
I also registered the higher GVWR at the DOL. In Washington, you can pay for a higher weight. My registration already showed 12K. I upped it to 14K, which is about where the truck sits with the camper on.
Old Oct 26, 2013 | 07:08 PM
MTMike's Avatar
MTMike
I don't have the 6.0 cooler, but I do flush it as recommended. I also have the tranny temp gauge. Good idea on the cooler.
--mike
Old Oct 26, 2013 | 07:27 PM
MTMike's Avatar
MTMike
I used to have a 73 F350 Super Camper Special. I had it licensed at 6000 lbs - as I recall, it weighed about 5400. I also had a 10 1/2 ft Vacationeer camper that weighed in around 2500 lbs as I recall and I towed 4500lbs of boat and trailer. This was in WA. I was told by the state that the camper license covered the camper weight and I did not need to pay for the higher GVW. That setup worked great!
I'll check out the threads on rv.net - what did all those extras cost if I can ask?
--mike
Old Oct 26, 2013 | 08:25 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Like the others have said...there isn't anything you can do to increase the GCVWR and GVWR ratings....those figures are set in stone at the factory.
That being said, I tow a fiver that weighs over 16k lbs with my SRW truck on a regulsr basis. Been doing it for about 8 years. Our brakes are undersized for that sort of weight so you need to keep your speed down and drive sensibly.
Get a good trailer brake controller such as the Prodigy P3 or similar and learn how to adjust it.
Make sure your tires are rated for 3415 lbs or higher and run the max pressure according to the sidewall.
A 6.0 trans cooler would be a good idea and might help your trans last longer however I think its likely the trans won't like towing that much weight and a rebuild will be in your future sooner than later.
You are going to need air bags. Having an on board compressor with in cab controls will make your drive much more pleasant since you can adjust the pressure as road conditions change.
In the luxury but not absolutely necessary category....
Helwig rear sway bar
Exhaust brake
C-betr mirrors
Happy towing.
Old Oct 26, 2013 | 09:31 PM
MTMike's Avatar
MTMike
Exhaust brake
C-betr mirrors
Happy towing.
Love my C-betr mirrors. Tires are E rated at 3415 so 6830 max on the rear axle. I'd guess rear axle weight to be around 3200 (with about 4000 on the front). That leaves me about 3600 max - the Hitchhiker 38 CE LKTG would have a pin weight of about 3200. It also has tripple axles with upgraded disc brakes so I would think it would stop OK.
The truck is at 180k miles now and the tranny is still super smooth, even when towing about 7500 lbs. Agree it is the weak spot.
Air bags are a good idea. Maybe some higher rated tires (G's).
So far, no one has given me a cost to "upgrade".
--mike
Old Oct 26, 2013 | 09:54 PM
BWST's Avatar
BWST
Got Data?
Ok costs:
Toyo 245/70R19.5/14 M-143 H-rated $401.13 each mt/balanced/installed
Vision 19.5 x 6.75 alum wheels $287.23 each
Stableloads (upper bump stops and lower wedges) $600 installed
RS9000 shocks all around $90 ea
Old Oct 26, 2013 | 10:09 PM
BWST's Avatar
BWST
Got Data?
That's good to know. I'll have to check that out...
Floridatex
Aug 1, 2013 07:32 PM
geezee
Feb 11, 2004 10:42 AM
workamper53
All Things Towing
20
Dec 11, 2003 01:16 PM
Tightwad
General Automotive Discussion
Jul 20, 2003 09:22 PM
rafterjf250
Jul 7, 2001 10:34 AM
