X Code Springs?
Old Jan 11, 2005 | 09:45 AM
blackx psd's Avatar
blackx psd
X Code Springs?
I have read about the X code springs but I have a few questions.
1. What all needs to be done besides just replacing the springs?
2. Will I have to change my shocks at the same time?
3. Where have people had the best luck on pricing for this item?
If someone could answer a few of these questions it would be great. Thanks.
Old Jan 12, 2005 | 08:18 AM
JoeBoost's Avatar
JoeBoost
I have been intrested in getting these for my truck as well.
These are the springs that will basically "level" the front end of the tuck, correct ?
Looking forward to seeing what people say , a Ford part # would be very helpfull as well
Old Jan 12, 2005 | 03:06 PM
xr7390GT's Avatar
xr7390GT
X codes will leave you nose high. They are part of snow plow package and intended to carry alot of weight. They will provide about 2.5 inches of lift to the front end. To level the front use U codes in V10 and V codes for PSD. This will raise front about 1.5 inches and provide the extra travel you need to avoid bottoming out.
You could replace U-bolts during swap also. Some think it is needed but I used originals.
I suggest using longer shocks even for the U or V codes based on my experience. I have a V10 and run U codes. I'm running F-350 part number Monroe reflex on the front. The extra height blew out my Edelbrock stock length shocks(they had 70K miles on them, about 25K with new springs). You can get by with stock length for U or V for awhile, but not for X.
I bought from dealer at cost $112 each. Lucked out on install, Ford wrench did for cash really cheap.
Search ford-trucks.com for posts by Bruce1954
Old Jan 12, 2005 | 03:11 PM
blackx psd's Avatar
blackx psd
Thanks for your help!
Old Jan 13, 2005 | 07:50 AM
JoeBoost's Avatar
JoeBoost
Is the part number for the V spring , " V-CODE" ?
Old Jan 13, 2005 | 09:19 AM
xr7390GT's Avatar
xr7390GT
No, Part numbers vary by weight rating and year. Check with a good Ford dealer. Check chart on diesel stop posted by Bruce 1954. It shows codes, weight rating and change in height.
TREX2000
Jan 3, 2012 08:50 PM
Sader
May 21, 2011 07:33 AM
Waynenap
Oct 31, 2010 09:53 AM
schmolke
Apr 29, 2009 08:59 AM
venom_99
May 6, 2006 08:01 AM
