clutch chattering
Old Jan 11, 2005 | 09:20 AM
Black89F150's Avatar
Black89F150
clutch chattering
Hi;About 18 months ago I replaced the clutch,pressure plate,slave cylinder and the pilot bearing on my 89 F150.I also had the flywheel resurfaced at our local machine shop.It is now chattering especially when starting out in first gear.Could a weak clutch master cylinder be the cause of the chattering?
Thanks for you help. Jack
Old Jan 11, 2005 | 01:55 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Probably not. Check all of the bolts between your engine and transmission. Check your motor mounts and transmission mount.
Old Jan 12, 2005 | 02:35 PM
low92flareside's Avatar
low92flareside
Probably a warped flywheel. Having it machined may not have resolved the problem.
mechelement
Jul 20, 2010 06:36 PM
ewxlt
Mar 25, 2001 11:59 PM
jams3
Feb 12, 2001 07:21 PM
RGAZ
Oct 16, 2000 08:49 PM
