Was wondering if anyone can shed some light on how to disconnect the backup sensor. I realize there is a button on the dash to disable but this only works for one repitition then it's back on. A fellow F-350 V-10 friend asked me as he plows snow and it's driving him nuts. I told him I didn't know but I'm sure somebody here has the answer. Thanks much!
Why disconnect it? As long as the yellow light on the switch says "off," then it's off. Each time you get in the cab, just hit the switch. As long as the truck isn't shut off, the sensing system will remain inoperative. That seems easier to me than disconnecting the whole system.
go under the rear bumper and look at the harness laced across connecting the sensors,, this harness has a plug up in there that can be disconnected,, kinda tucked away but it is up there,,
found this out when I bent the bumper on my 03 and had to replace,,
Reason: spelling error
That may be true on your truck, if it's new enough, but on his it no doubt works like it originally did: the systems rearms itself EVERY SINGLE TIME you switch out of reverse and then back in again. For a plow guy this certainly would drive you insane!
I know on the 6.0 trucks, the latest flashes allow the dealer tech, if he's savvy enough about things, to go in there and change the behavior to the new way. On pre-2003 trucks, or V-10 trucks, I have no idea if this is possible. Back in that era people talked about wiring a switch in series with the actual beeper speaker, which is part of the integrated backup sensor unit somewhere in the passenger footwell area.
Do a search on this forum, there was a service bulleten posted from Ford about how the backup sensor can be reprogrammed to remain disabled once the button is pushed as long as the truck is on.
I just had the reprogram done to my 04 f250, works great when backing in A trailer, push the off button once and it stays off, untill you cycle the key off and on.
I was at the dealer for A leak from the steering box, they whated to charged me for the reprogram, untill they scrwed up A power steering hose and had to keep the truck A third day. That when I told them they needed to do it for free.
How much did the stealership get to you for doing it?
Frank
They tried to charge me $46.95, but I said NO, as they hadn't informed me of a charge for this when the ticket was written up. They agreed and took the charge off.
Special Service Message # 17815 - MULTIPLE VEHICLES -- PROCEDURE TO DISABLE REVERSE SENSING SYSTEM (RSS) FOR ENTIRE IGNITION CYCLE - SERVICE TIP.
To program the reverse sensing system (RSS) switch so it will disable the RSS system for the entire ignition cycle, rather than turning back on each time the transmission is put into reverse, Perform the following using the NGS service card (Green Card) Level 10 or higher
1 Select service bay functions
2 select PAM module
3 Select module option content (Hit Trigger)
4 Select Vehicle (Hit Trigger)
5 Hit trigger to highlight IGN or REV
6 Scroll to toggle between IGN or REV (Hit Trigger)
7 Select done which is soft key #8 (Programming Should Now Be Complete)
Effective Date 05/20/04
