Dual tank selector switch
Old Aug 30, 2002 | 06:28 PM
Paso1's Avatar
Paso1
I am transfering from the donor truck the fuel lines, tank, wire harness, etc... Anyone know a test procedure fot the fuel select solenoid under the driver on the frame.
Old Aug 30, 2002 | 09:34 PM
82F100SWB's Avatar
82F100SWB
[updated:LAST EDITED ON 30-Aug-02 AT 10:35 PM (EST)]What year is the donor truck?
I just put my 82's cab on my 86 chassis, getting the wiring for the dual tank switch was a total PITA... It's part of the main cab wiring harness.... Also, my 86 had to have a/c and my 82 only a heater, so I couldn't swap the heater control to get the switch mount either....
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab:
460/T19/BW 13450 3.55 geared Full Floater 10.25 and Dana 50 TTB
1982 F100 SWB
300 HD: NP 435/2.75 geared 9", was the driver, now a parts donor.
78 F150, 351M/C6, eventually to be repowered with a 400
Old Nov 5, 2002 | 01:22 PM
madmacs's Avatar
madmacs
Just take the tank switch out of the panel and mount it elsewhere I put mine down by the side of the seat. I cut the harness out as far back as I could so I could attach new wires to it. I just drilled a ole large enough for the switch handle to go through, and place a small chrome plate over it and attached a small bolt through the bracket and its been there 15 years works fine.
Old Nov 5, 2002 | 03:31 PM
steve83's Avatar
steve83
You might also look for a Bronco with heater only - you can mount the tank switch where the rear window switch goes.
Old Nov 5, 2002 | 08:24 PM
gruveb's Avatar
gruveb
timpage
27
Aug 10, 2016 10:53 PM
swampthang
Mar 3, 2014 12:49 PM
Jon774
6.7L Power Stroke Diesel
Dec 23, 2013 04:25 PM
Poolguy601
Jan 6, 2013 05:20 PM
