CHARGING PROBLEMS
Old Nov 6, 2002 | 07:29 PM
dland's Avatar
dland
CHARGING PROBLEMS
I am having a problem with my 1985 E150 Van, 302/automatic. The charge is not getting from the alternator to the battery. I have had the alternator and the battery checked out, both are good. I have replaced the solenoid and the regulator. The problem must be between the alternator and the solenoid. What does a fusable link look like when it have burnt out and broken it's link? The one one my van appears to be fine. I'm going to test the black/red wire that goes from the alternator to the solenoid to see if there is a break of some kind, what else could possibly be wrong? When I first noticed this problem, my battery began to go down slowly, and then would not get charged back up at all. When I jump start with another car or fresh battery, it starts up just fine. Any help is appreciated, I am not very good at electrical systems.
Old Nov 6, 2002 | 08:45 PM
Mil1ion's Avatar
Mil1ion
CHARGING PROBLEMS
Fusible Link's are usually PINK.
I would have two differnt places test the battery to be sure.
You might get the V.O.Meter out and check for continuity on that wire.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 6, 2002 | 10:54 PM
steve83's Avatar
steve83
CHARGING PROBLEMS
You can tell a fusible link wire is burned by pulling the ends apart gently. If it's good, you can't; if it's burned, the insulation will stretch at the point it's broken.
Old Nov 6, 2002 | 11:41 PM
Ford_Six's Avatar
Ford_Six
CHARGING PROBLEMS
Check your body ground. Ford electric problems usually stem from the grounds. Try running a wire from the regulator to the neg. battery post. Use a ring washer on one of the screws holding the box to the fender along with a serrated washer.
Jared
Old Nov 7, 2002 | 04:27 AM
mshumack's Avatar
mshumack
CHARGING PROBLEMS
captain1997
Sep 13, 2011 10:25 AM
Stuckinmud
Electrical Systems/Wiring
Sep 10, 2008 10:05 PM
sdetweil
Jun 13, 2008 09:10 PM
vlcak
1983 - 2012 Ranger & B-Series
Nov 2, 2007 05:40 PM
dland
Oct 16, 2002 08:23 AM
