Headlight/Tun Signal/Chrome Housing question???
hey all,
i'm trying to replace my old turn signals - (on my '96 Bronco XLT) - with new clear, diamond cut ones.....and i have a problem...i can't figure out how to get the chrome housing off of the headlight area....the chrome piece that goes around the 3 piece headlight area...i can take off the two screws you see on top....but i cant figure out whats still holding it in there> i think there is either a clip or two or some screws.....can anyone help???
Will,
Anch, AK
Will,
Anch, AK
There should be two long bolt type things on the back connected to the turn signal ligt and u need to unscrew the nut on both of them and the whole housing should just fall right out.. u may have to move the battery and the windshield resevor and coolant overflow to the side to make it easyer to get the the bolts.. (You will need a socket wrench) -- by the way this was on my 1993 bronco, should still be the same..
FoMoCoFan52
13
04-03-2015 05:16 PM
makomaker
01-30-2008 10:17 PM
