1978 - 1996 Big Bronco
Headlight/Tun Signal/Chrome Housing question???
Old 01-09-2005, 05:04 PM
CompustarBronco's Avatar
CompustarBronco
CompustarBronco is offline
Question Headlight/Tun Signal/Chrome Housing question???
hey all,
i'm trying to replace my old turn signals - (on my '96 Bronco XLT) - with new clear, diamond cut ones.....and i have a problem...i can't figure out how to get the chrome housing off of the headlight area....the chrome piece that goes around the 3 piece headlight area...i can take off the two screws you see on top....but i cant figure out whats still holding it in there> i think there is either a clip or two or some screws.....can anyone help???
Will,
Anch, AK
Old 01-09-2005, 05:06 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
Enjoy FTE …..
See you on the boards.
Old 01-09-2005, 05:15 PM
BroncoBoss351's Avatar
BroncoBoss351
BroncoBoss351 is offline
Arrow
There should be two long bolt type things on the back connected to the turn signal ligt and u need to unscrew the nut on both of them and the whole housing should just fall right out.. u may have to move the battery and the windshield resevor and coolant overflow to the side to make it easyer to get the the bolts.. (You will need a socket wrench) -- by the way this was on my 1993 bronco, should still be the same..
FoMoCoFan52
13
04-03-2015 05:16 PM
makomaker
01-30-2008 10:17 PM
Krim
20
04-24-2007 11:20 AM
1FineBroncoBabe
79
03-04-2006 03:09 PM
Quick Reply: Headlight/Tun Signal/Chrome Housing question???
