Starter circuit
Old Jan 8, 2005 | 05:54 PM
1991f250's Avatar
1991f250
Starter circuit
I've got a 1991 7.3 idi with an auto that just developed a starting problem. I'm not getting 12v to the starter solinoid. If I short out the starter solinoid the starter motor turns. I traced the black wire back about 6" to another small relay... What does this relay do? Next step to trace the wires coming in to the relay for battery from the switch, or does it use a ground to start?
Old Jan 11, 2005 | 12:40 AM
PLC7.3's Avatar
PLC7.3
Did you check for power on both sides of the starter relay on the fender with key on and turned to start. The small wire sends power to close the relay does it have power key in start mode.
Next........
I would try putting the shifter in nuetral or wiggling it in Park to see if the manual position lever sensor on the trans is out of alignment. Check the MLP connector on the trans too. I would also check under the dash for the jumper for the Auto trans that replaces the clutch pedal start switch. It may/should have a red/light blue wire and be located under the dash to right of pedals.
Old Jan 17, 2005 | 01:36 PM
1991f250's Avatar
1991f250
Mystery solved! The relay in series with the starter relay was part of a alarm system... probably to disable the starter. The real problem was the ignition switch just quit working in the start function. I temporarily bypassed the start function of the ign switch with a push button switch under the dash. Guess I need to get one on order. Thanks for your help!
jmc86
18
Oct 5, 2014 12:27 AM
brandon badeaux
Jun 22, 2009 12:27 PM
newblder
45
May 18, 2008 01:09 PM
RyanGruhn
1978 - 1996 Big Bronco
Apr 11, 2003 01:26 PM
mooner
Jan 1, 2003 04:50 PM
