CDR valve...
Old Jan 17, 2005 | 08:12 PM
sealguy's Avatar
sealguy
CDR valve...
I was looking at vinford's post about the 6.9 head bolt. He got some excellent info about the CDR valve. Where is this valve located on an 89 7.3? I have the exact symptoms he described. Thanks.
Old Jan 17, 2005 | 08:15 PM
RhinoVirus's Avatar
RhinoVirus
Remove the air cleaner it is mounted at 12 oclock when looking down the barrel of your intake. it is mounted with two bolts to the intake and a rubber slip fitting into the valley pan.
Old Jan 17, 2005 | 08:23 PM
sealguy's Avatar
sealguy
Good deal. Thanks Rhino. I'll check that out tomorrow.
