drum size question
Old Nov 9, 2002 | 09:50 PM
electricmaniac2's Avatar
electricmaniac2
drum size question
Old Nov 14, 2002 | 04:57 PM
Njbmx's Avatar
Njbmx
drum size question
i just got back from advance auto. i wanted to but a new et of rear drum brake shoes. he asked me if i had an 10" drum or an 11" drum. then he told me that i had to measure the interior of the drum to find out. is there another way to accomplish this? is their a code? i have a '82 f-150 w/ 300ci. had 4sp. clark tranny, but now have comverted 3sp. thanks.
pete
Old Nov 14, 2002 | 09:33 PM
Franklin2's Avatar
Franklin2
drum size question
If you go to their website www.partsamerica.com you will see the many different types for your truck. They had a reference to gross vehicle weight rating, but i would just take and measure the inside of the drum to be sure.
Old Nov 14, 2002 | 10:31 PM
Ford_Six's Avatar
Ford_Six
drum size question
Just measure the backing plate and use good judgement. If the plate is around 11", you have 10" brakes. If it is 12", you have 11" brakes. If it is 14", you have a problem.
Jared
Old Nov 17, 2002 | 11:37 AM
steve83's Avatar
steve83
drum size question
The max diameter for honing is stamped into the drum somewhere, usually the outer edge on the outer face. Just pop a rear wheel off & look.
Old Nov 17, 2002 | 10:27 PM
Njbmx's Avatar
Njbmx
drum size question
thanks i will
pete
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
