TPS
Old Nov 15, 2002 | 11:22 AM
tom 84 ford's Avatar
tom 84 ford
TPS
Old Nov 15, 2002 | 03:30 PM
uf0844's Avatar
uf0844
TPS
Just changed the tps on the throttle body of a 302 with efi.can't make the idle receed to a normal range after warm up. Checked coolant flow to the throttle body and it appears normal. ANy suggestions would be helpful
Old Nov 15, 2002 | 05:26 PM
Ford_Six's Avatar
Ford_Six
TPS
Engine off, key on, adjust the TPS so the voltage reads approx. 1 volt.
Jared
Old Nov 18, 2002 | 09:49 AM
uf0844's Avatar
uf0844
TPS
checked the voltage and it reads 1 volt but idle speed is still high. checked linkage and damper. both these seem to be operating properly. still stumped, thinking maybe some pollution control sensor or bad wiring may be the culprit. whaddya think?
Old Nov 18, 2002 | 12:55 PM
Franklin2's Avatar
Franklin2
TPS
With the engine idling, pull the wiring plug off the idle bypass solenoid. The engine should struggle a little and then die. If it keeps running with this unplugged, your idle stop screw is adjusted to far in. Back it off so it closes the throttle butterfly more, and then try it again. This adjustment will get the throttle in the range where the idle bypass solenoid can control the idle.
