Offroad & 4x4
pulling truck set up ?'s
Old Jan 12, 2005 | 06:28 PM
fordman300's Avatar
fordman300
i can see them matbe picking it up off of the line but with 600hp i dont see him having a problem keeping some weight on the nose going down the track
Old Jan 12, 2005 | 06:44 PM
monsterbaby's Avatar
monsterbaby
the trucks have a weight limit, and the guys reach it by adding weight to the front ALOT of weight one of the guys around here runs 2wd without looking at the rules I believe the max is 4800lbs, his truck without the weights is 3100lbs then he hangs tractor weights, and still pulls the front wheels off the ground with a small block (unfortanatly its a chebbie), and is not running ag tires but has tire with almost no tread as they are ground down to about 1/2" lugs that look like wore out paddle tires. And with a NA 377 sbc I doubt he is even putting out 600hp.
Old Jan 12, 2005 | 07:52 PM
fordman300's Avatar
fordman300
okay i guess im wrong. I've just never seen it myself or figured enough traction could be mustered with that much weight on the front end to pull it off the ground
Old Jan 13, 2005 | 06:47 PM
78_351M's Avatar
78_351M
I have never seen a 4wd truck bring the front end up, but ive seen the backs come up. I agree with the at's, cause you can spin really fast and get good traction.
evan.kelly978
26
Mar 11, 2015 11:50 AM
ss74nova
33
Sep 12, 2014 10:12 AM
Ken2600
Jun 26, 2014 03:45 PM
trick26
Jan 20, 2014 03:38 PM
