I have a 92 E150 5.8 tanny shift fine got code 628 torque converter slip.at high speed if i let up off the gas i get a sound like i am running over railroad tracks.press on the gas sound go away. also got code 617 1-2 shifting tanny has 175k+ miles i dont know if i should put in a new converter,have my tanny rebuiled or get rebuilt one from ford. need help. just got a toy weekend warrior that about 4600lb empty. NEED HELP!
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
92" F-150 4X4, SWB 5.0 W/e4od. Soon to be 5.8 mildly built to 350 ish HP
Went to the Ford dealer today and was asking the $$ for a factory rebuilt E4OD, he said 2100.00 for a 5.0 or a 5.8. He said they showed different part #'s for each but didn't have the specs to tell me why the different ##'s.
TOLD HIM I HAD A 5.0 BUT WAS REPLACING IT WITH A 5.8.
Hope this gives you a little amo. Later, HOBO.LABO
