Sponsored by: Real Truck
Manual Tanny Help
Old May 5, 2013 | 09:52 AM
Chevmn56's Avatar
Chevmn56
Manual Tanny Help
I have the 6 speed (ZF) i know there is a cooling pump on this tranny. Is there a way that you can check the pump to see if it is working???? If not will it set a code??
02 7.3 CC
Old May 5, 2013 | 03:41 PM
TexasRebel's Avatar
TexasRebel
I guess the simple question is:
What makes you think it might not be working?
Old May 5, 2013 | 04:08 PM
Chevmn56's Avatar
Chevmn56
I have been pulling the same load for years(26' boat) i have a tranny temp gauge(yes on the manual). Pulling the same grade the twin sister hills in wyoming. The last two yrs the temp has been getting about 40 degerees hotter than the yrs past. Im running red line in the gear box.....and the fluid level and the fluid look good......I am just curious if the pump has give up the ghost. Or shes just getting old
Old May 5, 2013 | 04:34 PM
dsltech83's Avatar
dsltech83
Is the external cooler dirty, fins bent up? How many miles since fluid was changed in the trans?
Old May 6, 2013 | 08:26 AM
Chevmn56's Avatar
Chevmn56
Fins are good.......Ill give the fluid change a try! Probaly a good place to start........Is the pump internal or external
fordman19762003
Jun 10, 2013 07:23 PM
Caplax40
1983 - 2012 Ranger & B-Series
Aug 1, 2007 08:02 AM
Dogs-in-the-back
Jul 3, 2006 08:33 AM
SR77
Apr 3, 2003 08:45 PM
AggiePSD
Nov 14, 2002 08:43 PM
