hub bolts
Old Dec 11, 2002 | 02:21 PM
88grandmarquis's Avatar
88grandmarquis
hub bolts
truck listed below.
on one manual locking hub 2 of the 6 hex bolts have the head broke off. on the other side 1 is broke off and a few others look rusty.
what can i expect when taking off the manual locking hub and should i be able to get the remaining part of the bolts out since the heads are broke off?
also, what kind of replacement hex bolt is recommended? brand, type? i'd like something a bit stronger and durable than what is on there.
thanks.
Old Dec 11, 2002 | 05:58 PM
Franklin2's Avatar
Franklin2
hub bolts
[updated:LAST EDITED ON 11-Dec-02 AT 06:58 PM (EST)]Your worst case senario is, if you can't get the bolts out after they break off, you will have to buy new hub assemblies. I bought the cheapy Warn's for 60.00 and they have worked fine for the past 5 years. You can buy the nice all metal ones for more money.
Old Dec 11, 2002 | 06:17 PM
Ford_Six's Avatar
Ford_Six
hub bolts
If there is enough of the bolt left sticking out of the internal part of the hub, spray it down with PB Blaster, let it sit overnight, and then attack it with vise-grips. Ford should have the bolts in stock, NAPA might. You have to use the allen head style bolts, as there isn't enough room to get a socket on a hex head. Also, the torque spec on these is something like 16in/lbs, so go easy on the new ones.
Jared
Old Dec 11, 2002 | 07:40 PM
88grandmarquis
hub bolts
luckily they didn't break to far down and they didn't give trouble coming out. napa only had one pack and i put them in on one side and used some of the old ones for the other.
Old Dec 13, 2002 | 03:40 AM
Jens's Avatar
Jens
hub bolts
Hi all,
Isn't it possible to drill out the bolts and cut new theats in? If you can't make it, maybe an mashine shop could do it for you.
Jens
Old Dec 18, 2002 | 01:28 AM
cpettymore7777's Avatar
cpettymore7777
hub bolts
i usualy drill mine out anyway. when you take the cap off you will still have 2 1/2 inches of bolt left to turn out. these are easy as the cap assembly hold grease in there. you can usualy take them out with fingers.
Old Dec 18, 2002 | 09:48 AM
ddakota's Avatar
ddakota
Post hub bolts
alacarte
May 18, 2013 07:09 PM
RippedF350
Dec 27, 2010 12:10 PM
Smiley Pete
Aug 19, 2007 08:56 PM
Third Coast
Sep 24, 2005 09:39 PM
88grandmarquis
Offroad & 4x4
Dec 11, 2002 11:34 PM
