Head Bolt Question
Old Sep 23, 2005 | 09:40 PM
Third Coast's Avatar
Third Coast
Head Bolt Question
I am replacing the head bolts on my 226 flat six. I broke three off in the block( that is another story) The original bolts appear to have both a thicker and larger head than a standard hex head bolt. The originals are 7/16 -14 tpi and are 2 5/8" long. I can use a standard 2 1/2 inch 7/16 bolt but the head wont look like the original. I"m also trying to decide between grade 5 and grade 8. Any idea where I might find something that looks more original?? I looked at Mcmaster but couldn't find a heavy hex or a flanged hex that would work. What are your thoughts on plating vs. black bolts. Any info would be appreciated.
Old Sep 23, 2005 | 11:09 PM
45ford's Avatar
45ford
The 48-52 Truck Chassis Parts Catalog lists the 226 head bolt with the same part number as that of the 48-52 flathead V-8, so it should be readily available in the aftermarket.
Mike
Old Sep 24, 2005 | 07:05 AM
Narwhal's Avatar
Narwhal
I'd like to pull my heads on my 255 flattie, but the bolts look like they've in a long time. What's the best protocol for getting those out safely? They are kind of hard to get to to put any kind of rust breaker in. I've got an impact wrendh. Dennis Carpenter also wants $3.50 per bolt which sounds very high. What's a reasonable price for a quality replacement?
-Scott
'53 F100, doing final paint this weekend, maybe starting on electricals...
Old Sep 24, 2005 | 04:07 PM
mtflat's Avatar
mtflat
Impact wrench is the only way to go - even torque around the bolt. I bought my last set thru Hot Rods and Custom Supply - cost about $50 per 48 - 5 years ago - if I remember right.
Contact Red Hamilton at Red's Headers. He'll treat you fair.
Old Sep 24, 2005 | 09:39 PM
Third Coast
Thanks 45Ford. I ordered the bolts, I am going to have to get me a parts manual.
JJMac22
Oct 5, 2021 04:12 PM
KraZeDav
Exhaust Systems
Jun 29, 2016 07:46 AM
rwlacks
Dec 16, 2008 05:45 AM
76CamperSpecial
21
Aug 9, 2008 01:45 AM
sdetweil
Sep 15, 2007 11:28 AM
