Emissions test on my PSD...
Old Jan 3, 2005 | 12:49 PM
tonydshinycar's Avatar
tonydshinycar
Exclamation Emissions test on my PSD...
...Much to my surprise (thought my truck was too old) to buy new plates in Ohio for my 95' Powerstroke I had to have an emissions test. They ran the truck on the dyno on both tailpipes (mine y at the tailpipe). It passed, though my converter is hollow! The results were at 0.00 Opacity, limit 20.00 Opacity.
Can anyone tell me what Opacity is?
Thanks, Tony D.
Old Jan 3, 2005 | 01:47 PM
gjgogel's Avatar
gjgogel
Opacity is the percentage of light that is blocked by the exhaust stream. In Arizona, the metro areas also use this test for diesels. 20% is the limit here, too.
Old Jan 3, 2005 | 04:53 PM
1997F-350's Avatar
1997F-350
this may be a dumb question: do you mean the sun light being blocked by exhaust or something else? please elaborate because i am sure i am not the only one who doesn't have a clue. thanks
similar to los angeles on a clear day?(pollution)??????
Old Jan 3, 2005 | 05:20 PM
gjgogel's Avatar
gjgogel
The test is done by a light and light sensor device that is inserted into the exhaust pipe. If there is no smoke the reading will be 0.0. The blacker the smoke, the greater percentage of the light is blocked from the sensor. The limit is 20.0% of the light being blocked by the smoke. Anything over 20% will fail the test. According to the news reports here, there are very few failures because the rollers that they use to run the truck don't load the engine enough to produce black smoke unless there is a real bad fuel system problem.
binuya
Mar 6, 2012 09:06 AM
Pocket
17
Apr 27, 2011 01:59 PM
Smokin'
23
Jun 25, 2008 09:21 AM
Flip Dawg 6.9
Dec 8, 2005 11:19 PM
The Grinch
Feb 10, 2005 10:48 PM
