Sponsored by: Real Truck
running board light/wiring hookup
Old Feb 22, 2005 | 07:36 AM
Ernieford's Avatar
Ernieford
Tim yes the lights come on with the dome light and act the same.
Ernie
Old Feb 22, 2005 | 07:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Thanks and you have mail
Old Feb 22, 2005 | 05:49 PM
HeavyAssault's Avatar
HeavyAssault
TIM: I got that from a '04 manual, but it may be the same on your '05.
DIESELMAN929: Did you find the correct wire?
Old Feb 22, 2005 | 07:14 PM
IB Tim's Avatar
IB Tim
I think the 05 are different....bummer
Old Feb 22, 2005 | 09:33 PM
jello's Avatar
jello
On 2005 SD black/blue stripe in harness to the right of the steering column is dome light.
Old Feb 23, 2005 | 12:35 AM
Dieselman929's Avatar
Dieselman929
HeavyAssault
Where is tha wire located?
Larry
Old Feb 23, 2005 | 03:20 AM
HeavyAssault
It doesn't give a location. I figured it would be behind the driver's kick panel or running along the driver's lower sill.
Old Feb 23, 2005 | 06:46 AM
IB Tim's Avatar
IB Tim
Does that wire go back along the drivers side frame ....under the truck
Old Feb 23, 2005 | 03:21 PM
jello's Avatar
jello
sorry....right of steering column inside truck. Just remove big dash panel
Old Feb 23, 2005 | 07:41 PM
jasonschwenk's Avatar
jasonschwenk
so how about an '03 250? is it the black wire with light blue tracer?
also here is another twist
can i hook up to this wire(if it is the correct one) so the lights come on with the interior but also hook up so the running board lights come on with the parking lights?
Old Feb 23, 2005 | 08:49 PM
Hedgehog1's Avatar
Hedgehog1
The answer to all of your questions. I have 20 years experience as a certified installer of alarms, remote starts, etc. The wire you guys are looking for is black/lightblue trace. I have found it in two places on model years 2002-2005 depending on cab configuration and trim level. On the crewcabs and Lariat supercabs, the wire can be found about half way back in the driversdoor sillplate. It is in a small harness that comes from the rear of the cab and curves in under the driver's seat. On the XLT supercab 2005, I found the wire right in the drivers kick panel. Hope this information was helpfull.
P.S. I would use a relay!!!!!!!!!!
reamer
Mar 27, 2016 07:11 AM
F357
Feb 5, 2015 05:40 PM
HADESWRAITH
Apr 30, 2013 08:25 AM
Daewoo
Feb 10, 2012 09:28 PM
drifty4
2004 - 2008 F150
Oct 15, 2007 07:14 PM
