Dome Light Timer
Old Feb 9, 2012 | 08:40 PM
Daewoo's Avatar
Daewoo
Dome Light Timer
Is the dome light timer programmable? Mine stays on for at least 5 minutes after I shut the door and stays on for at least 45 seconds when I start up the Ex. After doing some searching of the forum, I swapped relay 4 and 5 and it didn't change anything.
Old Feb 9, 2012 | 09:30 PM
wallz's Avatar
wallz
That is why we do the dome delete mod. Basically adds a switch so when you want dome lights, switch on, don't want dome lights, switch off. Search for it as there are a few write ups on this.
Old Feb 9, 2012 | 09:35 PM
EXv10's Avatar
EXv10
They should go right out. Clean the connections in the rear hatch and slam it hard. You might need a switch in one of the 5 doors also.
Old Feb 9, 2012 | 09:49 PM
robert_l_ross's Avatar
robert_l_ross
5 minutes is way too long...sounds like your power safety relay is what is shutting them down. I'm thinking a bad door latch sensor. Hit all of them with a LOT of WD40 or the like to clean out the dust and gunk...should do the trick.
Old Feb 9, 2012 | 10:14 PM
Daewoo's Avatar
Daewoo
I will try the WD40 trick. I just did the lock actuator modification on the hatch and 3 of the side doors so I'm not opposed to trying the dome override mod too.
Old Feb 9, 2012 | 10:31 PM
robert_l_ross
Take pics...I've seen a few different ways to do it, so the more photos out there of the mod, the better!
Old Feb 10, 2012 | 12:15 PM
EXv10's Avatar
EXv10
Actually the light oil displaces the water so it can make a connection. Oil and water can't share the same space.
Old Feb 10, 2012 | 09:18 PM
robert_l_ross
??? It's not always water that is causing the problem...the point is a lubricant like WD40 fixes just about any cause...not just water.
Old Feb 10, 2012 | 09:28 PM
EXv10's Avatar
EXv10
But it is 90% of the time in the winter and oil takes it's place to fix the problem. It's not the cleaning properties it has, it's the ability to take place of the water to make a connection.
tfontaine1
Oct 28, 2017 08:34 PM
bluecobra
1997 - 2003 F150
Feb 29, 2016 10:17 AM
brd7666
General Automotive Discussion
23
Feb 17, 2011 10:37 AM
5.4L to Freedom
Jul 2, 2008 03:06 PM
97XLT4
1983 - 2012 Ranger & B-Series
Sep 6, 2004 07:46 PM
