Engine Switching Decisions
Old Jan 2, 2005 | 09:55 AM
flcbell's Avatar
flcbell
I have a 1979 F-350 with a bad 351m. I also have a 78 with a good 390 and a 400m avail to me for free that needs freshened up. I am in need of pro's and con's what to do.
Thanks Much
Old Jan 2, 2005 | 11:16 AM
LxMan1's Avatar
LxMan1
The 400 would be a direct bolt in. With a small 4bbl and a RV type cam along with an aftermarket timing chain set without the built in retard, it should run pretty good.
The 390 will need the frame mounts to be changed along with the tranny and all of the accessories on the front of the engine.
Old Jan 2, 2005 | 01:27 PM
fordfury469's Avatar
fordfury469
lxman is correct. 400 direct replacement,
Old Jan 2, 2005 | 07:58 PM
willow_tree's Avatar
willow_tree
use the 400. you can build these suckers up now seeing as that edelbrock has a nice intake for you, you carb of choice, and a crane cam. works good!
Old Jan 3, 2005 | 07:09 AM
flcbell's Avatar
flcbell
Thanks for all the input a 400 it will be.
BadBubble
Apr 15, 2014 02:01 PM
74scout
26
Jan 12, 2010 09:46 PM
61 uni
15
May 3, 2007 12:58 PM
79rancher_boy
Jan 14, 2004 08:24 PM
lr
Jul 20, 2000 10:37 PM
