HELP!!! sagging front wheels on ranger
Old Jan 1, 2005 | 11:46 AM
tma*fordman's Avatar
tma*fordman
Unhappy HELP!!! sagging front wheels on ranger
Hello-- my name is Todd, I am new to this site-- Can anyone help me with a bugging problem with sagging front wheels on my 93 ranger? I have asked 3 shops and they said it was simply because its a FORD and thats how Ford makes them, but 2 people have said that the ball joints are bad so I went back to the shops and they said ball joints were fine!!! Also I was told by several people to buy the camber adjusment brackets to prevent sagging from the J.C. WHITNEY auto supply. PLEASE HELP! My truck is a 1993 Ford Ranger STX extended cab 4x4 Sincerely-- TODD
Old Jan 1, 2005 | 01:29 PM
valo's Avatar
valo
the front wheels on a ford do sag. just keep them alligned.or you will start eating up tires . If your truck dosen't have it get the camber adjustment kit
Old Jan 1, 2005 | 01:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. As you can see, the members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 1, 2005 | 02:57 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!
The front tires should not sag when the vehicle is parked on the level, but it may look like it's sagging while driving under certain conditions where the front end travel (vertical) is extreme. If your's appear to sag while parked on level ground, an aligment is in order. If your sagging is visible while parked on the level and the shop you have visited calls that "normal", then go find a new shop. Your front end shop should then tell you if you need to get different eccentrics or anything else to correct the camber setting. Many front end shops keep "special" eccentrics on hand in anticipation of the incomming vehicles needing them.
Old Jan 1, 2005 | 09:33 PM
98xlt4x4's Avatar
98xlt4x4
With the TTB front end on yours, you probably will notice the problem more when you park after backing up. Pretty common with the Fords. I would go get the alignment checked firstoff though.
GreenMtnMan
1966 - 1977 Early Broncos
Jan 16, 2017 11:07 PM
Todd Berry
Large Truck
Oct 20, 2015 12:43 AM
garretttt4
Mar 10, 2015 07:44 PM
Don76fordman
Jan 7, 2015 02:57 PM
Molineguy
Jul 22, 2010 07:37 AM
