Sponsored by: Real Truck
Steering issue
Old Jan 3, 2015 | 01:06 PM
Don76fordman's Avatar
Don76fordman
Steering issue
I have a 2008 F-250 super duty and the steering wheel moves right to left very violently. It is an intermittent problem but happens a lot. We have not had it off road much, mainly pavement driving. We carry a load of firewood couple times a year so we really are not working it hard. We have checked the lock out hubs, ball joints and tie rod ends and they all seem to be fine. The tires seem to be wearing fine as well. After doing some research and talking with ford we arrived at a bad steering gearbox. Being that ford does not have a replacement available we ordered one through JC Whitney. After replacing the steering gearbox it drove fine for the first ten miles and then it started the right and left motion again. The pump sounds good and the fluid levels are fine. I have no clue at this point other than to just start changing parts out. I am not fond of parts changing. The truck is to dangerous to drive. I am in desperate need of any advice you all may have. Thanks
Old Jan 3, 2015 | 03:37 PM
Dpsinc1's Avatar
Dpsinc1
I had the same issue. Ended up being a bad u joint.
Old Jan 3, 2015 | 04:00 PM
Don76fordman
Did you have the steering issue in both four wheel drive and two wheel drive
Old Jan 7, 2015 | 02:57 PM
Don76fordman
Steering gearbox adjustment
I have been informed that the adjusting bolt on the steering box could be adjusted too tight. Does anyone have any experience with this adjustment, if so please let me know if this could be what is causing a remanufactured unit to cause this issue thanks
Heathnorrie51
Apr 5, 2019 04:19 PM
XLnAK
Sep 6, 2015 12:06 PM
Jlynch2011
Nov 28, 2010 10:29 AM
89Bulldog
1983 - 2012 Ranger & B-Series
Jun 15, 2010 10:04 AM
katbird704
Aug 26, 2007 06:24 PM
