Difference in R&P ratios
Old Dec 31, 2004 | 12:37 PM
peter.shell's Avatar
peter.shell
Question Difference in R&P ratios
I have replaced the kingpin type dana44 in the front of my truck with a newer balljoint type of axle. I got realy lucky with the R&P ratios, I think. I started with a 3.50 and now I have a 3.54. Can I run this without regearing the other axle to match? Thanks in advance.
Old Dec 31, 2004 | 05:28 PM
SoCalDesertRider's Avatar
SoCalDesertRider
3.50 and 3.54 are close enough to run them together without problems, just shift out of 4wd as soon as you reach hard ground so it doesn't bind up. My Bronco has that combination, kingpin Dana 30 with 3.54 front and Ford 9" with 3.50 rear.
Old Dec 31, 2004 | 05:59 PM
MustangGT221's Avatar
MustangGT221
As long as the two diff ratios are within 1%....you're good....it's close, but they should be ok as long as you're careful, be a little better on not using 4wd on hard/high traction surfaces. Usually the front is .01 below the rear, like 4.09/4.10 or 3.54/3.55...
Old Dec 31, 2004 | 10:12 PM
peter.shell
Hey thanks guys, I knew this would be the place to come for an answer. So stay off the pavement in 4 wheel drive. I have the matching R&P, do you guys think it would be a good idea to install it? I only put the truck in 4 wheel drive when I need to so I' not sure that it would be worth the time or money. Thanks again.
Old Jan 1, 2005 | 07:52 AM
MustangGT221
I myself would change them, as it's not that hard to change them if you know how....
evan.kelly978
Apr 10, 2012 04:50 PM
carbs & chrome
23
Jun 7, 2010 12:48 AM
1fastruck
2004 - 2008 F150
23
Feb 17, 2006 05:17 PM
sysadmin
Offroad & 4x4
Feb 11, 2003 06:55 PM
jonniekash
Jul 15, 2001 10:29 PM
