Differential/Gearbox ratios
Old Jul 11, 2001 | 05:41 AM
jonniekash's Avatar
jonniekash
FORD TRANSIT
I have replaced the single wheel rear axle on my Ford Transit R.V. with a dual wheel rear axle.
The single rear axle had a diff ratio of 3.89/1
The dual wheel rear axle has a diff ratio 4.63/1
What difference does this make to my R.V. ?
How can I obtain a similiar or lower ratio similiar to my previous 3.89/1 bearing in mind that replacement parts are extremely difficult for my model FORD TRANSIT?
Thanks a million
jk
Old Jul 14, 2001 | 07:53 PM
jonniekash's Avatar
jonniekash
TOO TOUGH FOR EVERYBODY Eh!!!!!!!!!
Where are all the KNOWLEGABLE
Old Jul 14, 2001 | 08:31 PM
Bill_Beyer's Avatar
Bill_Beyer
No it's not too tough but it is pretty stupid to ask a question then dis the same people you're asking.
By putting a numerically higher ratio rear end in your TRANSIT you are going to wind the engine higher to go the same speed you did with the lower gears. The only thing you can do is install an over-drive tranny or put on significantly larger tires. Is that concise enough for you?
Old Jul 14, 2001 | 08:41 PM
jonniekash's Avatar
jonniekash
Sorry Bill,
I have had my question posted for a while and noticed that most others had a response to theirs so added the "offensive" remark.
HOWEVER.......IT certainly brought a quick response.
Thanks a million...I certainly do appreciate your contribution and accept the rebuff
jk
Old Jul 15, 2001 | 05:10 PM
greg ne's Avatar
greg ne
I'm not too familier with RV rearends but on the trucks which may be the same if it has the same model axle there is no difference between the dual and single rear wheels except for the larger and longer wheel studs. You may be able to swap your original gears into your new axle and get off easy. Good luck Greg NE
Old Jul 15, 2001 | 08:57 PM
bigricker's Avatar
bigricker
Old Jul 15, 2001 | 10:22 PM
jonniekash's Avatar
jonniekash
Thanks Greg,
I had considered that as a remote possibility, but as one set of "axles" are full floating and the other semi-floating have somehow thought that they would not interchange as readily as one would like or hope for.
It is because of these uncertanties I have posted my enquiry in the anticipation that some more knlowlegable folk can steer me into optional alternatives.
I have had the suggestion of changing tyre sizes but this is extremely prohibitive due to our stringent regulations.
Thanks for your time, thoughts and suggestions.
jk
from the "land down under"
Old Jul 15, 2001 | 10:29 PM
jonniekash's Avatar
jonniekash
Thanks Bill,
You said........
"By putting a numerically higher ratio rear end in your TRANSIT you are going to wind the engine higher to go the same speed you did with the lower gears"
You are absolutely correct...this is what I've found..higher revs and presumably more gas.
You also said......"The only thing you can do is install an over-drive tranny"
Could you please explain what you mean by this statement...
Thanks a million
jk
from the land of OZ
HD
1983 - 2012 Ranger & B-Series
Jul 24, 2019 05:56 PM
1972RedNeck
Jan 14, 2017 10:41 AM
tiger100
Aug 15, 2015 07:48 AM
spiduci
May 20, 2015 04:31 PM
61Canuck
May 24, 2005 08:05 PM
